I'm looking to replace the rubber pad between the frame and my station wagon body. As you can see from the picture, the current rubber is toast. Does anyone have a source for vulcanized rubber material that I could use to re-create the original pads. Also, any ideas as to how thick they should be?
![]() Sent from my iPhone using Tapatalk
Youtube: https://www.youtube.com/@edselsadventures Instagram: https://www.instagram.com/edselsadventures/ |
Wouldn't the station wagon have used the same as other cars? If so, wouldn't the kit from the suppliers work?
I know the voices aren't real but damn they have some good ideas! ![]() |
Find an outfit near you that does repair work on conveyer belts. I would imagine they have a ton of stuff they would be all too willing to let you haul off and make your own pads.
Sidewall of an old tire?
Slice up some old rubber rain boots. Jeff Last edited by JDupuis; 02-08-2017 at 02:05 PM. Reason: Missed info |
Boiler gasket material works nice.Very stable under pressure,in all temperatures.Has a fabric core so it won't squeeze out.I haven't seen any rubberized conveyer belt that is thin enough for this use.I have used belting as shims to mount a 29 radiator on a 31 crossmember,it was 3/8 thick.I can't be sure,but for some reason 1/8 thick comes to mind for original pads.
I used conveyor belt material from Tractor Supply on my 150A. I think its about 3/16" thick. less than $20.
I had first bought the pad kit that the vendors sell, and, right outta the box, I saw it was not acceptable. (thin, unreenforced, and "cheesy"). I think the Rest. Guide has the dimensions listed.
______________ Nothing Short of Right is Right |
#8 | |
![]() Quote:
Thanks. I'll have to see where I can find some locally. I need to order a set of the guidelines... not planning on having the car judged, but I'm realizing there is a lot of info in there... Sent from my iPhone using Tapatalk
I used rubber cut from the side wall of an old Model A tire. 1/4 inch thick and plenty of cord in it like the originals. The pads sold by the parts suppliers has no cord in it and is too thin.
Lots of great suggestions. Thanks as always everyone for your help.
I went to a conveyer belt company and the guy gave me a 1 foot wide by 15 foot roll for free.
#13 |
I found a semi truck mud flap laying on the side of the road, and it was just right for making shims. It even had the fabric reinforcing in it.
Also, there is a conveyor belt company close to me, and he gave me some belting for free, when I mentioned it was for a Model A. |
#14 |
I got some good rubber in Sacramento - Many thicknesses, not inexpensive, but it's good reinforced material.
Capital Rubber SACRAMENTO 1725 19th Street, Sacramento, CA 95811 Phone (916) 498-1800 / (800) 662-1800 Fax (916) 498-1818 STOCKTON 1110 South Wilson Way, Stockton, CA 95205-7064 Phone (209) 464-1200 / (800) 624-1210 Fax (209) 464-2773 |
#15 | |
![]() Quote:
Thanks Dan. I've been itching to get up to Vintage Ford for a while. Maybe a trip to sack town is in order. Sent from my iPhone using Tapatalk
#16 |
More good information, thank for the tips.
#17 |
Hi,
I found reinf. rubber material at McMaster-Carr. Part#s in photos. Hope this helps. Jim |
#18 |
The only thing i use!
A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
#19 | |
![]() Quote:
Thank you so much for the parts numbers, I just placed an order. Sent from my iPhone using Tapatalk
#20 | |
![]() Quote:
I got some from my brother-in-law and I found many uses for it. It's 1/4" thick.
1929 Coupe 1930 Coupe 1935 Ford 5 window coupe |
