Old 01-18-2017, 06:45 PM   #1
Mitch//pa
Default Re: Hard to turn engine over A ford 1929
Originally Posted by tom wesenberg View Post
cranking the engine with the key off will eliminate any timing concerns.
Connect a volt meter to the battery posts and read the voltage while cranking.
Lay an inductive ammeter on the starter cable and read the amps while cranking.
Originally Posted by dick steinkamp View Post
good point, tom!
post #17
Old 01-18-2017, 08:11 PM   #2
Dick Steinkamp
Dick Steinkamp's Avatar
Originally Posted by Mitch//pa View Post
post #17
...and Mitch!
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
