Old 01-04-2017, 07:32 PM   #5
RUNNERBUN
RUNNERBUN's Avatar
Default Re: Mitchell Overdrive - Shift Lever Knob - Ruckstell?
I thought I could give you the answer, went out to the garage and tried to remove the knob from my T Ford Ruckstell but it would not budge. (not sure if it's threaded or bonded).
As Paul and Seaslug have said just buy one and modify if it does not fit.
I would just drill out the incorrect size thread and JB weld an appropriate sized nut back in. The only tool required for the job is a drill.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
