Are you sure that's a Ford engine in there? I cannot imagine how you can even touch the camshaft in a Mod. A engine unless you have the oil pan off. Is this the case?. If you are that far into the engine, then why not take the radiator off and remove the cam, replace the old lifters and put a set of adjustables in the engine.
You'll be much happier in the long run! Terry [QUOTE=bwaii64; I ran my fingers over the cam lobes (mostly to see if I was off the lobe) and didn't feel wear which I would expect to be a rough surface, ).[/QUOTE] |
