Old 01-03-2017, 09:25 AM   #1
ericr
ericr's Avatar
Default timing pin substitute
do any of you guys remember a substitute timing pin that was sold some years ago, that was spring-loaded, such that you did not have to unscrew the timing pin., merely press it on it till it fell into the dimple, then release?
did anyone ever buy it? does anyone still make it?
ericr is offline   Reply With Quote
Old 01-03-2017, 09:37 AM   #2
zzlegend
zzlegend's Avatar
Default Re: timing pin substitute
Only one I have seen is this one. Don't think this is what you are talking about.
http://www.snydersantiqueauto.com/timing-pin-tool-3669
zzlegend is offline   Reply With Quote
Old 01-03-2017, 09:42 AM   #3
ericr
ericr's Avatar
never seen that accessory before! it is different because the thing I used to see was a permanent installation.
I suppose part of the theory was if you started the engine without removing the "fumble pin", as it was called in the old ads, it hogs out the dimple.
Old 01-03-2017, 10:16 AM   #4
29spcoupe
29spcoupe's Avatar
I bought one in Hershey, made of brass. Well done and works as advertised. I don't leave it in the timing cover, just screw it into the cover when I use it, then replace the original timing pin when done. I found it in the chocolate field across from Tam's, but forgot the vendors name.
29spcoupe is offline   Reply With Quote
Old 01-03-2017, 03:08 PM   #5
MrBruce
MrBruce's Avatar
Yes, I've run one for years. I don't remember where I bought it and would buy an extra one if I saw them on the market. Sorry I don't remember, but it has worked great, never a problem
MrBruce is offline   Reply With Quote
Old 01-03-2017, 05:00 PM   #6
Synchro909
Synchro909's Avatar
I think some one here on the barn showed one they had made themselves a while ago. Making one shouldn't be too difficult but as is often the case, it might not be worth the effort if one is available cheap enough commercially.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-03-2017, 05:43 PM   #7
SeaSlugs
SeaSlugs's Avatar
Spring loaded brass thing with a keychain ring? I Got one - amazingly simple and effective tool! about the size of the timing pin itself.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-03-2017, 06:00 PM   #8
29spcoupe
29spcoupe's Avatar
That's the one!
Old 01-03-2017, 06:07 PM   #9
1930-fordor
1930-fordor's Avatar
Sounds interesting,
Would someone be nice enough to post a picture
1930-fordor is offline   Reply With Quote
Old 01-03-2017, 06:38 PM   #10
29spcoupe
29spcoupe's Avatar
Originally Posted by 1930-fordor View Post
Sounds interesting,
I went out to the garage to take a picture, can't find it. I put it somewhere so I wouldn't loose it, and now I can't find it. I'll have to look tomorrow in the daylight.
Old 01-03-2017, 06:45 PM   #11
SeaSlugs
SeaSlugs's Avatar
sure its not in the car in a tool box or attached to the ign key?
id post a pic but dont know the seller and wouldn't want to undermine his sales by people making thier own if someone remembers the name or has a contact others could buy from him that would be great! - I did hear snyders bought a whole buncha them to sell in thier catalogs - I dont know if the guy has caught up for that large of order or not :P
Old 01-03-2017, 06:46 PM   #12
Synchro909
Synchro909's Avatar
Haven't we all done that! Never clean up your workshop if you ever want to find stuff again.
Old 01-03-2017, 06:58 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I do that all the time. Why does it always backfire?
Timing is a cause of backfiring. I better check my timing.
Old 01-03-2017, 07:26 PM   #14
jm29henry
jm29henry's Avatar
I,me with you 29& Tom
jm29henry is offline   Reply With Quote
Old 01-03-2017, 07:27 PM   #15
jm29henry
jm29henry's Avatar
Alway shows up when your not looking for it!!!��
Old 01-03-2017, 08:10 PM   #16
DougVieyra
DougVieyra's Avatar
Post #15: "Alway shows up when your not looking for it!!!"
_______________________________________
Yeah - but by the time you see it again , you don't remember that you were ever looking for it !
DougVieyra is offline   Reply With Quote
Old 01-03-2017, 09:06 PM   #17
Synchro909
Synchro909's Avatar
I'm finding this thread very comforting. I'M NOT ALONE!!
Old 01-03-2017, 11:06 PM   #18
steve smith
Put the pin in with rubber bands holding it in. Hand crank slowly using both hands and watch the pin slip into timing dimple then STOP ! You got it . Throw away the rubber bands cause you Won't remember where there are. Always change rubbers as needed.
steve smith is offline   Reply With Quote
Old 01-03-2017, 11:12 PM   #19
ian Simpson
That's what my dad told me
ian Simpson is offline   Reply With Quote
Old 01-04-2017, 05:12 AM   #20
Bruce of MN
Bruce of MN's Avatar
I usually find it after I buy a new one.
