Old 01-01-2017, 12:43 AM   #1
H. L. Chauvin
Default Re: rust in water
Probable January 2017 Addenda to be added to the former Model A Lubrication Charts:
Note: Forget about the former caution not to clog your radiator tubes by over-greasing your Model A water pump; however, to insure your radiator stays spotless and clean, check your oil to water ratio and grease to water ratio in your radiator often.
All new cars will use this radiator cleaning and rust preventative method soon.
H. L. Chauvin is offline   Reply With Quote
