Old 12-14-2016, 05:10 PM   #1
Johnnydidd
Johnnydidd's Avatar
Default new tool
I am trying to post a new tool I developed. I will post on swap meet trying to see if it works thanks guys
Johnnydidd is offline   Reply With Quote
Old 12-15-2016, 09:17 AM   #2
Johnnydidd
Johnnydidd's Avatar
Default Re: new tool
Does this tool appeal to you?
Old 12-15-2016, 10:36 AM   #3
Oldmics
Now I am always for a better tool,however please tell me why this is better than the screwdrivers that I have used for this chore in the past?
Respectfully,Oldmics
Oldmics is offline   Reply With Quote
Old 12-15-2016, 04:15 PM   #4
Johnnydidd
Johnnydidd's Avatar
Oldmics, the reason its better is on account of the self aligning feature, you place the tool on the screw head and turn it falls into the slot, with a screwdriver you have to try to hit the slot, plus you can adjust the idle speed with the air breather on. I will be happy to discuss in more detail call 913 832 5001
Old 12-15-2016, 09:57 PM   #5
y'sguy
y'sguy's Avatar
I think I've already got a set similar to those I inherited from my Dad. Just sayin' good idea.
y'sguy is offline   Reply With Quote
Old 12-20-2016, 06:10 PM   #6
Beav
Beav's Avatar
Not to rain on your parade but Snap-On, and others, have had similar tools for years. TM83a, TM84, TM85. The difference being theirs attach to a 1/4" drive tool...
Beav is offline   Reply With Quote
Old 12-21-2016, 09:14 AM   #7
Johnnydidd
Johnnydidd's Avatar
Thanks for the info, they make a very nice tool, difference is mine can be purchased either alum or plastic. Plastic conducts heat at a slower rate, also I am selling this tool to adjust air/fuel mixture on carburetors. This tool is made in USA, I make it on my work bench. My price is $6.00, compared to $15.75 and $20.75. This USA1000 is made 2 barrel carbs, Tool USA1001 is made for Holly 4 Barrel. thanks John
Old 12-27-2016, 04:28 PM   #8
Old2New
If you were to put notches on it so it's easy to see how much adjustment is made then it would be a one up on the competition. Maybe colored notches at top and bottom and left and right so I can adjust for half turn and quarter turns? Could be useful for sure.
Old2New is offline   Reply With Quote
Old 12-28-2016, 07:41 AM   #9
Johnnydidd
Johnnydidd's Avatar
I can do that, how many notches, four? I can build one if you like. any advice is appreciated. thanks John
Old 12-30-2016, 01:13 AM   #10
Daves55Sedan
Daves55Sedan's Avatar
I can appreciate your ingenuity. I have a sloppy old 2-ton rolling floorjack I use pretty often and get frustrated when you can't get a good enough grip on the handle to be able to turn the pressure screw out for letting the jack down with greasy or dirty hands. To remedy this once and for all time, I made my own tool with the same type of end that you have from a scrap piece of pipe, broken screwdriver, metal sleeve with a hole drilled thru and a piece of steel rod to use as a crank/lever. Required a little cutting, grinding drilling and welding to make. When not in use I just throw it on top of the floorjack so its there when I need it.
If most folks are like me, we use the tools that we have that will work even if they are a little inconvenient, modify substandard tools to make them better, and manufacture our own tools out of necessity. I've got a whole toolbox of homemade tools and then some. I'm guessing I'm not alone.
Hope you have good luck marketing your new tool.
Old 12-30-2016, 06:34 PM   #11
Diavolo
Diavolo's Avatar
Just an fyi
https://store.snapon.com/Carburetor-...e-P630999.aspx
And in my field, we have these. I guess I could shop around and find something a little stronger, but for adjustments, I think they would be fine. Used to adjust potentiometers. I think I can buy one for ~$4.
https://www.amazon.com/Alignment-Phi...s=trimmer+tool
Diavolo is offline   Reply With Quote
Old 12-31-2016, 03:19 AM   #12
Old2New
I think everyone has to admit that there is a certain beauty to homemade tools. Its awesome to know that in your tool box there is no one else in the world who has a tool exactly like that one.
Old 12-31-2016, 04:46 PM   #13
Kahuna
Kahuna's Avatar
I'll buy one, John
For Holley 4000 4 bbl carbs?
Jim
Kahuna is offline   Reply With Quote
Old 12-31-2016, 08:07 PM   #14
Johnnydidd
Johnnydidd's Avatar
I will be glad to sell you one, it is 12.00 plus 3.00 shipping, you can order on line or call 913 832 5001 thanks Kahuna
Old 01-02-2017, 03:39 AM   #15
Daves55Sedan
Anybody ever try to remove or tighten the large locknut inside the trunk lid that holds the lock cylinder on these cars. That funny shaped hole they got doesn't give ya room for a regular wrench and the nut is way down in there. So I manufactured my own wrench that will reach down in there with a handle that sticks out so you can grab on to it outside the hole.
Everytime I pass by that toolbox and see that tool in there it always made me wonder how other people were re-installing their trunk locks. Bet they don't have a tool like I do ! Hehe.
