Old 12-22-2016, 02:26 PM   #1
Eskildsm
Default HELP- New to model A's
I recently bought my second model A. Me and my wife are new to older car arena though we both have loved older cars. The model A coupe deluxe I bought for my wife has a significant oil leak coming from right behind the oil pan. I took some pictures but not sure you'll be able to see. Anyway I took the little 1/2 moon panel off that is right behind the oil pan and leak appears to be coming from where it looks like it runs into the tranny. I attached a couple of photos but not sure if you can access them. I have read some about the oil cap-- mine just slides right onto oil filler tube. Any help ???
Eskildsm is offline   Reply With Quote
Old 12-22-2016, 02:56 PM   #2
Barber31
Barber31's Avatar
Default Re: HELP- New to model A's
Welcome to the barn! It's prably a rear main oil leak. Super common on a lot of our vehicles. I'm sure you'll hear lots of recommendations from folks on here but there's also lots of info if you search the old topics regarding this issue.
Barber31 is offline   Reply With Quote
Old 12-22-2016, 02:58 PM   #3
1930artdeco
1930artdeco's Avatar
The oil return pipe should screw into the cap. If it is plugged then it will leak. Have you checked the clearances yet?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-22-2016, 03:15 PM   #4
Eskildsm
Here's pic of my oil cap and tube. The cap just slides onto it. I don't see any return line??
Old 12-22-2016, 03:20 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Mike was talking about the oil drain pipe on the rear main bearing cap.
On your oil fill cap, just look under the cover and you should see 3 or 4 tab that stop the cap from being press on so far it blocks off the air flow.
Old 12-22-2016, 03:26 PM   #6
Eskildsm
Where is the rear bearing cap located-- sorry to sound so dumb just getting to know these things
Old 12-22-2016, 03:19 PM   #7
Fred K-OR
Fred K-OR's Avatar
How bad is the leak? Cover the garage floor or just a drip? If just a drip, Model A's are known for "marking their territory". Some of the guys on this site will give you some good advise on how to check this out. Otherwise if it is a small leak, maybe just a rug under the car when you park it may take care of it. The vendors also sell a "diaper" that you can bolt on the flywheel housing to keep the drip from falling on the floor. Good luck and have fun with your new "toy".
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-22-2016, 03:20 PM   #8
Eskildsm
Having hard time getting pictures to post??
Old 12-22-2016, 03:22 PM   #9
Eskildsm
It's a substantial leak there were probably 20 drops when I backed in driveway and by time I shut it off oil leak on floor of about 3" circle.
Old 12-22-2016, 03:40 PM   #10
zzlegend
zzlegend's Avatar
I think people are jumping to far ahead of you. New to model "A"'s.? Most peoples answers are regarding dropping the oil pan, which it sounds like you are nowhere near that stage yet. That's where the oil pipe and rear main cap is located. Its not easy to make sense of some of the replies when you are new to these cars. Take your time.
zzlegend is offline   Reply With Quote
Old 12-22-2016, 03:53 PM   #11
Bob C
Could be as simple as to much oil or as serious as needing new bearings.
Start with the simple stuff first.
Bob
Old 12-22-2016, 04:42 PM   #12
JOHN CT
JOHN CT's Avatar
Bob
Bob is right start with the easy stuff first. Did you change the oil and possibly added to much. Are you parking on a hill ?
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 12-22-2016, 04:42 PM   #13
Eskildsm
So I know it doesn't have too much oil it's about 1/8" below full on dipstick. The oil almost looks a greenish color more like gear oil. Once I let car warm up it starts to seep from area behind oil pan where there's little 1/2 moon panel. If you increase the Rpms of the engine it starts to leak quite bit more. We live in Montana however spend our winters in az where we are currently so I have very limited tools and space as we rent a house here. Not sure what my next step is as we would like to use it while we are down here in Nice weather.
Old 12-22-2016, 04:44 PM   #14
Eskildsm
Not on a hill and parked in flat garage
Old 12-22-2016, 05:04 PM   #15
Fred S
Fred S's Avatar
The easiest thing to do first, would be to drive it at 35 mph or less without the oil fill cap for awhile. If the leak stops, the cap was sealing the oil fill tube, causing oil to be forced out of the rear.
Fred S is offline   Reply With Quote
Old 12-22-2016, 05:11 PM   #16
Eskildsm
Will do that next-- thanks will post my results
Old 12-22-2016, 05:54 PM   #17
aermotor
If none of the above suggestions work it's time to pull the pan. Oil running down the pan is usually a pan seal, running out the clutch housing drain a bearing issue. What as far as dripping can you live with until fix-it time? I would pull the pan on any unknown history of cleaning anyway.
John
aermotor is offline   Reply With Quote
Old 12-22-2016, 05:43 PM   #18
700rpm
700rpm's Avatar
It is a bad rear main bearing. Buy Les Andrews' red book. Available from most suppliers, and from mafca.com publcations.
Ray Horton, Portland, OR
Old 12-22-2016, 05:53 PM   #19
Eskildsm
What makes you 100% sure it's a bad bearing -- just wondering ??
Old 12-22-2016, 07:18 PM   #20
700rpm
700rpm's Avatar
57 years' experience with Model A's. But I would be happy to be proven wrong, for your sake. It could be the pipe, it might be the gasket at the back of the cam, but the volume and location of the leak as shown in your pix tell me it's the main. Keep us posted.
