Old 10-17-2016, 04:19 PM   #1
William Kelchner
William Kelchner's Avatar
Smile 30 Shutting off
My 30 was running fine a few weeks ago, then it started acting up missing and coughing through the carb. Here is what I have done up until today. Checked voltages and spark - all good. Battery was on its last legs installed new 6V. Started it up on the main tank and it runs for a few minutes then dies like fuel starvation.
Borrowed a small auxiliary fuel tank, put fresh gas in it and checked the fuel flow (good) fired it up and does the same thing.
Since I eliminated the main tank and the gas I would guess, in my limited knowledge, that this blasted Zenith carb may be the culprit. Seems like it empties the carb fuel bowl and then shuts off. It will restart once or twice and then finally just crank away. Checked the carb fuel filter which was clean.
Any suggestions are welcome. Bill K
William Kelchner is offline   Reply With Quote
Old 10-17-2016, 05:09 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: 30 Shutting off
If the carb fuel bowl is emptying then you DON'T have good fuel flow..............
Paul in CT
Old 10-17-2016, 05:38 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Remove the carb bottom and hold a small pail under the carb. Turn on the gas and watch the flow. If it's good, then you must have blocked passages or jets.
Old 10-17-2016, 07:14 PM   #4
Jacksonlll
Jacksonlll's Avatar
I assume you cleaned the plugs.
Old 10-18-2016, 12:50 AM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Have you checked the carb filter and float valve?
Old 10-18-2016, 08:29 AM   #6
William Kelchner
Thanks for all the replies. Replaced the float valve a couple of months ago, checked the carb filter which is clean. I too wondered about fuel flow and thought by completely bypassing the main tank with a separate tank would eliminate the main tank and shutoff valve as a possible source of the problem. The fuel flow from the main tank and the separate tank/fuel line look about the same.
I'll tinker with this a bit more today and see what happens.
Old 10-18-2016, 08:29 AM   #7
Terry, NJ
Terry, NJ's Avatar
William, I am going through this with my "new" coupe. I've had it a little over two years and for the most part, it's run well. But all of a sudden it seems a flood of rust has been shaken loose from the walls of the tank.Two days ago,I took the carb (Mod.B) off and took about a tablespoon of rust grit from the bowl. I cleaned every passage and jet. I put it back on a started it and it ran for about a minute then it quit , again! Mitch has suggested using a Wix 33039 or a NAPA 3039 that fits in the glass filter bowl. I'm going to put one in the system.
Terry
Old 10-18-2016, 08:41 AM   #8
Mitch//pa
Terry
I also suggested to make sure you have the standup filter on the shutoff
Old 10-18-2016, 10:01 AM   #9
William Kelchner
Smile Re: 30 Shutting off
Thanks. Going to replace my carb with a known working carb today - one of the forum members coming over today or tomorrow with it. Let us pray
Bill K
Old 10-18-2016, 10:22 AM   #10
eagle
eagle's Avatar
Sometimes a fuel issue turns out to be an electrical issue. I know you state that you checked for spark. However it may be worth your time to do a quick check on point gap. Over time the point block wears and then the points don't open enough. Will run but hard starting and missing coughing is what happens.
Old 10-18-2016, 04:33 PM   #11
William Kelchner
Thanks Mitch and yep got a pencil filter.
Old 10-18-2016, 04:37 PM   #12
William Kelchner
Boy am I aware of most carb problems are electrical Would you believe today and the car put on its performance I again checked the points - I have spark 40 percent of the time I'll check that tomorrow, poor Zenith gets blamed for everything.
Bill K
Old 10-18-2016, 06:00 PM   #13
Benson
New ignition points need to be re-adjusted several times after installing them.
One thing to remember about ignition points is that the rubbing block wears rapidly for the first 200 to 400 miles then it "work hardens" and wears less from then on.
How fast this happens has a lot to do about how smooth the dist cam rubbing surface is.
So it is necessary to check the gap several times right after they are installed to be sure that the gap has not closed up.
Old 11-30-2016, 02:27 PM   #14
William Kelchner
Update - I quit the Model A has won!
Old 11-30-2016, 02:30 PM   #15
Mitch//pa
How much u want for it
I'll tow it away for free
Old 11-30-2016, 02:33 PM   #16
DJ S
DJ S's Avatar
Have you made any progress?
DJ S is offline   Reply With Quote
Old 11-30-2016, 02:39 PM   #17
bambooboy
bambooboy's Avatar
walk away from it for a few days
bambooboy is offline   Reply With Quote
Old 11-30-2016, 02:44 PM   #18
William Kelchner
I just tried out my rebuilt, flow tested, engine tested Zenith from one of our major suppliers and same scenario. Good gas flow, spark, points, voltage everywhere, starts nice, timing is good. Runs good for several minutes. I hung a wreath on the radiator and said a few words over it.
Bill K
Old 11-30-2016, 02:50 PM   #19
1crosscut
1crosscut's Avatar
William,
Pull your distributor and check the flexible wire under the top plate. It may be your trouble.
If it is going bad it will cause lack of power, coughing and back fire.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 11-30-2016, 03:43 PM   #20
William Kelchner
When it dies or briefly running it is without fanfare, no backfire, missing, coughing, just a sigh.
