Old 09-26-2016, 02:23 PM   #1
wmws
Default Speedometer lube
Can anyone tell me what kind of lube and where to lube in the speedometer. The gears look rather dry and the odometer stopped at 10,000 like it didn't want to turn that fifth number. I have the number cylinder out but can't seem to get it apart any further. Any help would be appreciated.
wmws is offline   Reply With Quote
Old 09-26-2016, 04:21 PM   #2
Ron/IA
Default Re: Speedometer lube
http://www.modelahouse.com/tech/spee...r/fischer.html
wmws-I used the above article to completely rebuild my speedometer several years ago. I hope you find it helpful.
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 09-26-2016, 05:49 PM   #3
wmws
Thanks Ron. Looks like a detailed article. I will be studying for days.
Old 09-27-2016, 09:47 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I've always used Dist Cam grease.
Bill Slick
"THE ASSISTANT GURU OF STUFF"
Old 09-28-2016, 07:20 AM   #5
Rex Perry
The procedure that was identified in post #2 is most excellent. I would add that it is very necessary to remove the primary worm gear before trying to press out the main shaft. There is a rectangular washer under the magnet wheel with a curved edge that must be up away from the odometer wheels. In a hasty move to fix the position of that washer, I failed to remove the primary worm gear and ruined it in the process. I now need to find a replacement worm gear. Be careful.
Rex Perry is offline   Reply With Quote
Old 09-28-2016, 08:33 AM   #6
wmws
Thank you all for the helpful information. I will go slow and try not to break anything.
