Old 09-05-2016, 01:25 PM   #32
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Re: Looking for a Particular T5 Thread
Thanks but no - we are trying to mate a Chevy p-plate to a Ford clutch disk for a Ford T5 trans. This requires a special t-out bearing setup, which is resolved, but the clutch disk is only on about 1/2" of splines on the main shaft to the trans. I need 3/4" plus of byte on the splined or else I will just shear off the main shaft splines on a hard launch.
Mush of what is out there is for a Chevy pattern T5 - the Ford is different, takes a different adapter. My tabs usxa T5Z which is the trans Tremec based on.
Read back in the thread and you will get more info .....
TomT/Williamsburg is offline   Reply With Quote
