Old 09-04-2016, 05:37 PM   #1
tubman
tubman's Avatar
Default Re: "Squish" problems
"Saltracer", now that you say that, it makes perfect sense. The only thing I can think of is I was planning on doing it, but never got around to it. I've had the heads on and off this engine so many times this summer my head is spinning. It also doesn't make sense that the squish should be less when both gaskets measured the same .050" when compressed. I think I'm getting too old for all of this.
Ross, luckily, the engine had only been together about a week, so everything came apart easily. Is that .050-.055 you measured on a new or used gasket?
Old 09-04-2016, 10:03 PM   #2
saltracer
don't feel back, I did something similar. Except I switched out heads without checking clearances and the pistons hit the heads so hard they caved in a little!
saltracer is offline   Reply With Quote
