Checked closely - did not find a crack.
Tried the gasoila sealant, allowed to dry for 24 hours +, leaked ![]() Ordered Permatex Aviation #2 - now all back together and letting her cure overnight. Fingers crossed! |
#2 | |
![]() Quote:
If it's leaking externally at the gav area look at the plugged area at the bottom of the GAV, maybe it's weaping or you have a crack. I've had a carb or two have some issues in this area. Good luck... confident you will find it! Larry |
#3 | |
![]() Quote:
EXCELLENT idea, Larry! I will be using your method this afternoon. Thank you! |
