Just asking,why are they not made with a hole
The hole is to let air escape as you fill the cooling system. Water goes into the block through the lower hoses and as it fills air need to be expelled at the top.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
#3 | |
![]() Quote:
Vent open for filling: ![]() Vent closed when water pumping: ![]() The Stant thermostats that I use and recommend have a notch in the valve plate that lets the air through when filling. It is visible in this photo of the Stant on the right. Left is the current stock replacement stat just showing the comparison of the openings in each for water to flow through - the Stant obviously bigger. ![]()
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 08-26-2016 at 06:18 PM. |
