Old 08-24-2016, 05:05 PM   #6
Willit Stop
Willit Stop's Avatar
Default Re: 97 Carb Fuel Bowl
A few things off the top of my head.....
-The float may be sunk.
-Wrong gas cap (non-vented). Remove the cap and see if that helps.
-Remove the fuel line from the carb,shove a rubber hose on and put the other end in a quart jar.Turn on the electric pump to make sure you have a good flow.
Is the pump still working when the engine is running?
Beyond that, I'm stumped.If it's still driving you crazy,you could join my support group?(Just kidding) Good luck.
Willit Stop is offline   Reply With Quote
