Old 07-23-2016, 04:52 PM   #1
TommyCoupe
TommyCoupe's Avatar
Default Quick generator question
For some reason the (made in Taiwan) ammeter burned up today. The car was just sitting there, not running, with the key off (I think) and smoke started bellowing out of the car.
I think there may have been a short in the ammeter, or maybe the wires connecting to the ammeter, but I will look for other possible shorts.
The only other thing that I think I could possibly have wired wrong is the yellow/black wire to the generator. It does go on the side marked "Bat" right?
I've been running the car a bunch of times, and never had a problem until today.
Tommy-
TommyCoupe is offline   Reply With Quote
Old 07-23-2016, 05:22 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Quick generator question
BAT side is correct.
Try to find a good original ammeter. I suspect your meter was junk and one of the terminals may have shorted to the case. The nuts holding the wires on the ammeter are special insulated thumb nuts available from the parts suppliers.
Old 07-23-2016, 05:26 PM   #3
Mitch//pa
Inspect your entire dash harness carefully , they are around 10.00 you may want to replace it...
Here is a thread from a customers car I just did... Basically the same issue
http://fordbarn.com/forum/showthread.php?t=198484
Old 07-23-2016, 06:35 PM   #4
TommyCoupe
TommyCoupe's Avatar
Tom, I think the ammeter may be junk too. I have the original ammeter that I originally didn't want to use because the glass was kind of ugly. I found out today that it's pretty easy to clean up, so i'll use it.
I'll check all the connections and make sure nothing else is shorted before I put it in.
Mitch, you're right, I will have to replace a few wires. A couple of them look a little toasty.
thanks for your help guys.
Tommy-
Old 07-23-2016, 06:57 PM   #5
Joe K
Joe K's Avatar
Check back side of terminal box. Some of the reproduction boxes allow the two bolts (terminals) to "back off" and short themselves to your firewall.
Joe
Shudda kept the horse.
Old 07-23-2016, 06:59 PM   #6
Mitch//pa
Pretty cheap
Old 07-24-2016, 07:14 AM   #7
TommyCoupe
TommyCoupe's Avatar
Yup. Need to replace those guys, and probably the yellow and yellow/black wires that go to the starter and generator.
Seeing smoke come out around the gas tank is no fun.
Tommy-
Old 07-24-2016, 10:42 AM   #8
Y-Blockhead
Y-Blockhead's Avatar
Tommy-
That's one of the things that has always concerned me, having all the current (Amps) going thru the ammeter right next to the gas tank.
IMO it would be much safer to have a volt meter (reads volts, no amperage) in place of the ammeter. Wish I could find one the correct size.
And yes, I know, not original...
Old 08-07-2016, 04:54 PM   #9
TommyCoupe
TommyCoupe's Avatar
Smoked another ammeter today.
I put a battery disconnect switch in and replaced the wires that I cooked.
I double checked and triple checked the wiring diagram, and I think everything is right. How hard can it be, right ?
Then started the car and smoke came out of the dash again. I quickly hit the disconnect and saved the wires from being cooked again.
I've been thinking that something is messed up with the generator so I unhooked the generator. The wire and the cutout were really hot.
I took some pictures with the cover off the cutout. I'm not sure, but I think the screw that the wire attaches to, is so long that it touches the generator case.
This electrical issue is driving me nuts.
Tommy-
Old 08-07-2016, 05:19 PM   #10
wmws
I had a similar problem with my cut out. The insulator between the screw and the cover got out of place and allowed the cover to short out. It just kept blowing the fuse I had on the starter so didn't melt anything. I would try and see if it is OK with the cut out cover off.
wmws is offline   Reply With Quote
Old 08-07-2016, 05:58 PM   #11
Bob C
I assume everything is ok until you start the engine?
Bob
Old 08-07-2016, 06:32 PM   #12
Tom Wesenberg
Your cutout looks cooked to me. I'd give Bert's a call for a restored original cutout. 800-321-1931
Old 08-07-2016, 06:46 PM   #13
bambooboy
bambooboy's Avatar
first couple things i did to my trk(after reading the forum for a while) battery cutoff on top of post,no battery floorboard cover.after running i shut off gas till rough idle,pull back carpet turn battery cutoff knob.also a long time trick to check generator operation.engine should keep running with battery disconnected
bambooboy is offline   Reply With Quote
Old 08-07-2016, 07:27 PM   #14
TommyCoupe
TommyCoupe's Avatar
Car runs fine on just the battery, and no smoking when the generator's unhooked.
I'll give Berts a call and try again. Probably should buy another ammeter. I may have to change my username to Ammeter Tommy.
Old 08-07-2016, 10:29 PM   #15
jax55
jax55's Avatar
IF the screw is touching the case, get a shorter screw! As Tom said, the cutout coils appear to be cooked, that could be your problem as well.
Get another cutout and try again. If you replace the screw and cutout and still have a problem.... let us know.
jax55 is offline   Reply With Quote
Old 08-08-2016, 10:54 AM   #16
katy
katy's Avatar
What about the screw on the side at the the generator terminal? Does it happen to be touching the case?
Old 08-08-2016, 11:03 AM   #17
tbirdtbird
Yikes, we got guys running their cars with the battery disconnected!!??
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-08-2016, 11:55 AM   #18
SeaSlugs
SeaSlugs's Avatar
If you have company stock in light bulb manufactures that's not a problem but yea its a good way to burn up the generator and all light bulbs that are on if you run it without a battery connected. Might wanna go check and see if you have brake lights bambooboy...
Seems like a good case to add the fuse to the starter switch and invest in an EVR instead of a relay (cutout) or at least the diode version.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-08-2016, 12:46 PM   #19
Tom Wesenberg
That screw should be removed, as it serve NO purpose, and no wires get connected there. I'm wondering why it was installed in the first place?
Anyway, the cutout is cooked and should be replaced with a good original restored one from Bert's.
800-321-1931
Old 08-08-2016, 01:32 PM   #20
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Tommy,
It's fairly common for cut out screws being too LONG & shorting out to the case.
REMEMBER, most terminal pliers have threaded holes, to shorten common screws. (TIP#173)
Bill Short
"THE ASSISTANT GURU OF STUFF"
