Old 07-29-2016, 09:26 AM   #1
expavr
expavr's Avatar
Default Re: trans up date to over drive
Originally Posted by chuck stevens View Post
Thanks for the kind words, I'm not sure what year the trans is, it was a flea market find last winter in Florida. Les, you're set up looks much cleaner than mine. The biggest problem I had was getting the detentes of the top shifter to coordinate with the side loader detentes.... extra holes in the levers and adjustable linkage. This will be set into place without the body so the clutch set up will be easier, Chuck S.
Chuck
If the detents continue to be an issue consider using a spring with lighter pressure in the detent galley in either the shift tower or the trans. It will make shifting a whole lot easier. I chose to do it in the shift tower to insure that one of the detent balls didn't inadvertently drop into the transmission due to the reduced pressure. PM me. I'm curious about your design, especially how you dealt with the horizontal brackets from the shift tower to the transmission wanting to rotate on the axis of the sliding shafts in the tower and how you modified the forks to attach the horizontal brackets.
Les
expavr is offline   Reply With Quote
