Old 07-29-2016, 01:20 AM   #1
roasterx
Default I found this in the middle of the desert
Can you guys tell me if this is a Model T? Or what it might be?
https://goo.gl/photos/58hfvMGYTdmLqZcq8
https://goo.gl/photos/PEg5GDPKfiCLnQL27
roasterx is offline   Reply With Quote
Old 07-29-2016, 05:31 AM   #2
big job
big job's Avatar
Default Re: I found this in the middle of the desert
No Ford had a cowel vent before 1933. Plymouth Pontiac no enough left for ID
big job is offline   Reply With Quote
Old 07-29-2016, 07:38 AM   #3
texas webb
Drag it home.
texas webb is offline   Reply With Quote
Old 07-29-2016, 10:37 AM   #4
redmodelt
redmodelt's Avatar
While I am waiting for photo to down load. There were cowl vents on the 1924/25 closed cars (coupe, tudor and fordor). For 1926/27 only the fordor had the cowl vent the coupe and tudor had the gas tank under the cowl. I would have to check but I think the later closed TT (ton truck) had cowl vents also. Some of the early fordor Model A's had vents in the side of the cowl.
I could not down load the photos. Could you post them here?
Old 07-29-2016, 10:43 AM   #5
Jeff Hood
Not Model T. T's did not have that large of a cowl or the bright trim band. The rounded rear roof is also not Model T.
Jeff Hood is offline   Reply With Quote
Old 07-29-2016, 11:58 AM   #6
Royce P
Royce P's Avatar
Looks like a Pontiac, about 1930 - 31. Not much there.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 07-29-2016, 03:07 PM   #7
roasterx
Thank you for replying. I was hoping to find a desert Model T - an old romantic idea of mine.
Old 07-29-2016, 04:28 PM   #8
roasterx
Originally Posted by texas webb View Post
Drag it home.
Dude,
That's kind of the idea, but I am not sure if it's worth it. I was hoping it was a Model T, so I could live out an old fantasy of mine by rebuilding one I found in the desert.
Old 07-29-2016, 04:31 PM   #9
roasterx
I would love to post them here, if you could teach me I'll do it. Thank you for replying.
Old 07-29-2016, 04:33 PM   #10
roasterx
Thank you for replying. I was hoping it was a "T," but alas, I'll stumble across one sometime out here.
Old 07-29-2016, 04:35 PM   #11
roasterx
Thank you for your help. I was looking at a 1931 Pontiac after reading your response, it sure looks similar.
Old 08-05-2016, 01:29 PM   #12
rileyracing
rileyracing's Avatar
I'm thinking Model A...
Barnstormers VSC- Celeritate Est Vita
Battery Fabrication Technologist- Ford Motor Company
Antique Vehicle Mechanic- Greenfield Village
Sometimes Docent - Ford Piquette Avenue Plant
Member #347- Early Ford Registry
rileyracing on the HAMB
rileyracing is offline   Reply With Quote
Old 08-05-2016, 01:30 PM   #13
rileyracing
Or maybe 32 Chevy looking at the cowl...
Old 08-05-2016, 01:31 PM   #14
rileyracing
A T would look like this...
Old 08-18-2016, 12:45 AM   #15
1948 sedan
Send a message via AIM to 1948 sedan
26-27 Ford had a cowl vent,,,,,
1948 sedan is offline   Reply With Quote
Old 08-27-2016, 12:46 AM   #16
RUNNERBUN
RUNNERBUN's Avatar
Most definately not a FORD car. Looks like about 1929/30 but can't say what make.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 09-07-2016, 09:11 AM   #17
yachtsmanbill
yachtsmanbill's Avatar
Theres a spare sidemount well in the passenger side fender. ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 09-12-2016, 01:45 AM   #18
Randy in ca
Randy in ca's Avatar
Dash looks a lot like 1928-29 Hudson.
Randy in ca is offline   Reply With Quote
Old 09-12-2016, 05:27 AM   #19
WRA
WRA's Avatar
Hudson looks to be the most plausible. Not a Ford, regardless there is a value once you get an ID.
WRA is offline   Reply With Quote
Old 09-12-2016, 09:12 PM   #20
WestCoast
Dodge?
WestCoast is offline   Reply With Quote
