Old 12-26-2010, 08:45 PM   #1
glenn in camino
glenn in camino's Avatar
Default Re: Model A Garage & Heat???
Forgive me for bragging, but in the process of building my Model A garage, I bought a radiant heating system from Radiantek.com in Vermont. They shipped it to me and my contractor and I installed it before the floor was poured. It's heated by a high efficiency water heater powered by propane. The tank is outside. It stays 65 degrees in my garage 24/7, even when it's in the 20s outside, with no fan blowing air and dust and with no flames or noise. I wish I had it in my house. I highly recommend radiant heat for any new building.
Old 12-26-2010, 09:30 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Glenn, what do you expect your water heater is using per month in propane? Does the burner cycle on quite a bit as it is circulating or does the water make several cycles through the floor before the burner has to reheat the water? Do you expect fuel consumption is about the same as what your house water heater uses?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-26-2010, 09:52 PM   #3
IrishHills
IrishHills's Avatar
Probally not the best but I use a 6' 1910 Round Oak wood stove, 30 x 40 pole barn 10' ceiling, built out of cedar no insulation at all, work in a T shirt on coldest days.
Keep in mind propane is lighter than air, Very Dangerous!!!
Edit: meant to say heavier than air... thanks Guys
IrishHills is offline   Reply With Quote
Old 12-27-2010, 02:53 AM   #4
Mustang
Mustang's Avatar
Keep in mind propane is lighter than air, Very Dangerous!!![/QUOTE]
Sorry – The real (or perceived) danger of propane
is because it is heavier than air, and tends to pool
at floor level rather than dissipate into the air.
It also has 2.5 times the BTU content per cu ft vapour
compared to natural gas, so a bigger boom for your buck.
For those with high ceilings, a hardware store plain Jane
‘reversible’ ceiling fan at ceiling level, blowing upwards
in the heating season forces the warm air trapped at the
ceiling to flow across to and down the walls, giving
better efficiency and comfort with most heating systems.
Regards
Art
Mustang is offline   Reply With Quote
Old 12-27-2010, 03:03 AM   #5
sturgis 39
I think you have it backwards. Propane is heavier than air.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 12-27-2010, 03:32 AM   #6
sturgis 39
I heat my shop with propane. electric and wood stove. It is 16'x20' and insulated. The propane is an infrared heater with two burners feed with a seven pound bottle. I turn it on while getting the wood stove going. I have installed a carbon monoxide monitor. The electric heater is 240 volt wall mount unit that I plug into my welding outlet. I do not use it much.
I went to a stove place the other day. I wanted to buy a pellet stove. The guy said propane was half the price of pellet stoves (dollars per BTU). I went to Menards and they have propane heaters for garages that do not have to be vented. They have oxygen sensers but they will not operate above 4500' elevation very well. They are wall mounted and about 9"x3'x4'. They tell what size for a one to three car garage. My elevation is 5600 feet so I will probably not buy one.
I think I will buy a good wood/coal stove and and throw a lump of coal in for the night. My wood stove is getting to in bad shape.
Old 12-27-2010, 11:03 AM   #7
glenn in camino
The system runs now and then during the day depending on the outside temp and is on a thermostat for each room. My garage has 3 rooms that I can control individually. I don't keep track of the propane use.
Old 12-27-2010, 05:07 PM   #8
Jerry Parr WI
Jerry Parr WI's Avatar
I agree in floor radiant heat is the best way to go. My brother did it with his garage and his house. Difficult to retrofit but the next time I break up the concrete in my garage floor I will install it.
When it's in the 20s here we call that a heat wave and people shed their winter coats.
Jerry Parr WI is offline   Reply With Quote
