Old 07-27-2016, 06:40 PM   #1
41LINC
Default Rear hub "keepers"
After redoing my rear axle bearings , I keep hearing about these "keepers"
What are they and where can I find them.
Thanks for any help
41LINC is offline   Reply With Quote
Old 07-27-2016, 06:58 PM   #2
flatheadfan
flatheadfan's Avatar
Default Re: Rear hub "keepers"
I think this is what you are seeking. They hold the hub ('39-'48), to the backing plate in case of an axle break. If so, just about any speed shop will have them. Speedway would be a good start.
Tom
flatheadfan is offline   Reply With Quote
Old 07-27-2016, 07:05 PM   #3
41LINC
Many thanks ; tried Speedway . Is there another name for them ?
Old 07-27-2016, 07:08 PM   #4
40cpe
40cpe's Avatar
Drum or axle retainers
http://www.speedwaymotors.com/Early-...iner,1981.html
Old 07-27-2016, 07:10 PM   #5
russcc
There often called safety hubs, as they were required for racing in the flathead era. If you want quality USA ones I would contact Vern Tardel.
Old 07-27-2016, 07:12 PM   #6
JSeery
JSeery's Avatar
Part # 91031365
Old 07-27-2016, 07:33 PM   #7
41LINC
GOT IT ! Thanks to all
Old 07-27-2016, 07:35 PM   #8
Ken/Alabama
Ken/Alabama's Avatar
This is the one I use.
Old 07-27-2016, 08:13 PM   #9
swanwaco32
Ken/Alabama. Where can you buy the weld on style? Thanks John
swanwaco32 is offline   Reply With Quote
Old 07-27-2016, 08:33 PM   #10
Ken/Alabama
Don't know, I wish someone would remake those. I've had these for years and using them on my Zephyr. These are some originals probably made in the 50s
Old 07-27-2016, 08:49 PM   #11
41LINC
NEVER saw that style Ken . Looking for safety on my '41 Continental
Old 07-27-2016, 10:18 PM   #12
19Fordy
19Fordy's Avatar
You can buy the old style safety hubs like Ken has here:
http://www.reds-vintage-parts.com/ou...-new-old-stock
and
Or, if you have some 1/8 inch steel, a vise, a saw a drill and a welder you can make your own. If you decide to make your own notice how the top (1/4 in. thick) surface has a curved contour for clearance on a 15 in. rim. 16 in. wouldn't need the contour. Use thin plywood to make your protypes.
19Fordy is online now   Reply With Quote
Old 07-27-2016, 10:32 PM   #13
Zephyr Q
Zephyr Q's Avatar
Interesting, something else that I didn't know I might need.
Zephyr Q is offline   Reply With Quote
Old 07-27-2016, 11:19 PM   #14
Bassman/NZ
Bassman/NZ's Avatar
Those retainers only work on car drums. I have pickup brakes and drums on my diff, and the drums don't have the right shape lip.
Bassman/NZ is offline   Reply With Quote
Old 07-28-2016, 11:51 AM   #15
19Fordy
19Fordy's Avatar
Bassman; Just curious to know what your drums look like. Are they like the 1939 Lincoln drums? Can you post a photo of your drum's configuration?
Old 07-28-2016, 07:10 PM   #16
Bassman/NZ
Bassman/NZ's Avatar
They're very similar to the car ones, but the vertical lip that the retainer sits over is not vertical, it's on enough of an angle on the outside edge that the retainer will neither fit nor have any grip if the axle breaks.
Old 07-29-2016, 09:10 AM   #17
19Fordy
19Fordy's Avatar
Wonder if you could make a set of retainers that compensated for that non-vertical mounting surface?
