Old 07-20-2016, 07:56 PM   #1
Andy
Default Re: II need a longer Pitman arm; is a comparison chart out there?
All of the V8 arms are about the same length.The Model A arms are longer but have the square shaft, You could weld an A arm to a V8 hub. The A is about 2" longer. Pic is of V8 arms. 37-48.
Andy is offline   Reply With Quote
Old 07-21-2016, 12:04 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Andy View Post
All of the V8 arms are about the same length. Pic is of V8 arms. 37-48.
I'd venture to say that the one on the left is probably '35-'36, as I've found them to be a little shorter than the '37-'48s. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-21-2016, 07:09 PM   #3
Andy
Coop.I believe you are right. It is an old pic.
