Build it the way YOU want it to look and run - the way that makes you feel good....Screw the purists....
Your oil filter is a Ford authorized accessory introduced in 1939. Its design was modified in mid 1940 to change the oil return line from fuel pump banjo fitting to distributor banjo fitting. It was later changed to return directly to the oil pan at the dipstick, and was available in that configuration for the rest of the flathead era.
[QUOTE=JM 35 Sedan;1322404]'37 or early '38 21 stud engine, prior to intro of '38 24 stud.... [QUOTE] John, The 24 stud was introduced as job 1 in 1938, and due to overproduction of the 1937 21 stud, that engine was also job 1, until inventory was depleted, different dates at different plants.
Alan Last edited by ford38v8; 07-12-2016 at 12:17 AM. |
