Good to know, I never inquired when I was around Roy, I figured he wouldn't want to divulge too much info about his suppliers....I wouldn't. I can buy and match a lot of the fasteners used but the problem on the commercial market most of the time is in the "Correct" finish.
I can tell you IF he is doing some (or most) on his own he has quite an investment in equipment to do so. Cold heading machines, dies, presses and heat treating equipment for stress relieving. Then...all the plating vats and materials and the constant EPA inspections and disposal of said material, especially cadmium....It would be quite impressive if he's doing it on his own.
