Old 06-19-2016, 02:08 AM   #11
flatheadmurre
flatheadmurre's Avatar
Default Re: Burning points??
You have metal migration on the points so capacitor value is not as it should be.
The coil resistance is on the lower end so that shouldn´t be an issue.
The balance of the points is set by coil/cap combination if cap value is low metal goes to one side if value is high the other side.
Try a new cap and points.
