Old 06-18-2016, 05:17 PM   #4
SofaKing
SofaKing's Avatar
Default Re: Lifting cab on 35 PU
Originally Posted by V8COOPMAN View Post
Yeah, and a 1935 pick-up DOESN'T have hood hinges, either! DD
DD, you are number 1 with me!
As the hinge runs down the hood centerline, the hinge is supported on the cab and the belt-line of the hood is immediately below the bends of the hood panel. The distance from hood hinge centerline to hood beltline remains unchanged regardless of what you do with the cab height. Do you have a photo of the misalignment you are trying to correct? After re-reading your query I see that you are trying to align a belt moulding and a photo might be useful to confirm definition of terms.
SofaKing is offline   Reply With Quote
