Old 06-11-2016, 12:23 AM   #2
RalphM
RalphM's Avatar
Default Re: Remove ignition key
Try getting some powdered graphite and putting it in the tumbler around the key. Try and get as much as you can in. Then giggle the key lightly, it may just be the lock has gotten gummed up from age. If it's an original lock cyl. Even if it isn't try this.
RalphM is offline   Reply With Quote
