Old 05-26-2016, 01:43 PM   #1
Cornishman
Cornishman's Avatar
Default Removing the Radiator Cap on a 1931 Model A
I am in the process of replacing the waterpump on my car. As the car has a four blade fan I need to remove the radiator. Following the instructions in my Les Andrews Volume 1 I started removing the radiator shell. All was going smoothly until I reached stage 7, remove the radiator cap. How? I presume that I need to undo the two Allen (hexagonal) screws inside the filler. Is this correct? There are no detailed instructions. Can anybody help?
Cornishman is offline   Reply With Quote
Old 05-26-2016, 01:46 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Removing the Radiator Cap on a 1931 Model A
Yes and turn inward carefully do not unscrew all the way as the brass ends will fall in rad. Easy will come off easy. They go under the lip of spout.
www.whidbeymodelaclub.com
Old 05-26-2016, 03:41 PM   #3
700rpm
700rpm's Avatar
You can't just turn the cap counterclockwise and remove it? I guess I don't understand what the difficulty is.
Ray Horton, Portland, OR
Old 05-26-2016, 03:46 PM   #4
Cornishman
Cornishman's Avatar
I have discovered that it is a locking cap held in place by two Allen headed screws. I now have a few days' delay before discovering how easy it is to remove as I have had to order a set of imperial Allen keys, all mine are metric.
Old 05-26-2016, 03:46 PM   #5
Divco one
Divco one's Avatar
I believe it's a Quail cap.
Divco one is offline   Reply With Quote
Old 05-26-2016, 03:54 PM   #6
Cornishman
Cornishman's Avatar
No.
Old 05-26-2016, 03:54 PM   #7
Fred K-OR
Fred K-OR's Avatar
If it is other than a "regular" cap, you may have a Quail(?) meter type or something like this. I know on my 1929 I did have to use an Allen wrench to remove it. Don't know if you have the same on your 1931. And yes they are not metric.
I know I had a few choice words about my cap the first time I took it off until I discovered the Allen screw.
Forget the above, did not post till a couple of above posts. So that is not your problem.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 05-26-2016, 04:01 PM   #8
Cornishman
Cornishman's Avatar
Originally Posted by Fred K-OR View Post
If it is other than a "regular" cap, you may have a Moto (?) meter type or something like this. I know on my 1929 I did have to use an Allen wrench to remove it. Don't know if you have the same on your 1931. And yes they are not metric.
Quite right. I was just a bit surprised that the Mechanics' Handbook dismissed it so simply as everything else is described in such detail.
Old 05-26-2016, 04:04 PM   #9
CarlG
CarlG's Avatar
There should be a metric key that is close enough to get it to turn the screws. I can't ever keep my US Standard keys and metrics straight, they are all mixed up most of the time.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-26-2016, 04:26 PM   #10
Cornishman
Cornishman's Avatar
I tried every key I have without any luck so I've ordered the imperial set anyway. I've got other jobs to do on the car while I'm waiting for them to arrive.
Old 05-26-2016, 05:15 PM   #11
diomed
diomed's Avatar
I've pulled the radiator before leaving the shell on. It's more difficult to remove and install the radiator mounting bolts but you can still do it.
Sent from my Nexus 6P using Tapatalk
kris
diomed is offline   Reply With Quote
Old 05-26-2016, 08:50 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
On my 28 and 29 I remove the radiator and shell as a unit.
Won't the fan with 4 blades come out by just tipping the radiator ahead?
Maybe remove the light bar to tip it more.
Old 05-26-2016, 10:32 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
There are a couple of different caps so not having detailed instructions on a specific cap is not a surprise.
That is how I have done it. I also place a piece of cardboard between the fan and radiator.
Old 05-28-2016, 08:44 AM   #14
KGBnut
KGBnut's Avatar
Cornishman, forgive me if I am pointing out the obvious, but I didn't see anyone else mention this...
The reason that Les Andrews doesn't explain how to remove this is because it is not standard. What you have is an aftermarket "anti-theft" radiator cap. It is designed to keep someone from stealing your Moto-Meter, or other fancy radiator cap. The original radiator cap was just a quarter turn and lift it off. This one requires tools to remove, and will (hopefully) discourage a thief.
I don't remember what size Allen (Hex) wrench you need, but I don't think it is metric.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 05-28-2016, 09:02 AM   #15
Cornishman
Cornishman's Avatar
Ken
That would have been my thought but there is a big but. On the very same page he explains about how to remove aftermarket headlamp systems. As its obvious that a large number of cars have been fitted with the Allen screws I think it's strange that that is not mentioned as well. It really is no problem, I'm quite happy to wait for the Allen keys to arrive so I can do the job properly. In England we have a saying, 'If a job's worth doing it's worth doing well.'
Old 05-28-2016, 09:05 AM   #16
Cornishman
Cornishman's Avatar
I should have said, 'Thank you' for this reply days ago. Sorry. It is exactly what I needed to know.
Old 05-28-2016, 10:40 AM   #17
katy
katy's Avatar
If you don't have time to do it right the first time, where are you going to find time to do it right?
Old 05-28-2016, 02:50 PM   #18
KGBnut
KGBnut's Avatar
I took a look at mine, and much to my surprise, the Allen heads are metric. Mine are 4.5 mm. I never would have guessed.
Ken
Old 05-28-2016, 03:18 PM   #19
Cornishman
Cornishman's Avatar
Ken
That makes sense, 5mm was too big and 4mm too small and I don't have a 4.5mm. The set I've ordered does. Thanks.
Old 05-28-2016, 07:09 PM   #20
1931 flamingo
1931 flamingo's Avatar
Mine has screw slots, I believe it's from the late 80's.
Paul in CT
