05-20-2016, 03:36 PM | #1 |
Engine trouble
any ideas what might be wrong i have a flathead 39 ford 85 hp. the motor will start when it is cold after it warms up and i shut it down it will not start it will turn over and over and over i just put new plugs coil adapter 6 volt coil had the carb rebuilt any ideas of what the problem might be? any help in this matter would surely be appreciated. thank you JIM S.
05-20-2016, 03:47 PM | #2 |
Re: Engine trouble
Do you have spark at the plugs when it won't start?
Bob |
05-20-2016, 04:22 PM | #3 |
Re: Engine trouble
if no spark try a new condenser and or coil
05-20-2016, 07:37 PM | #4 |
Re: Engine trouble
put on old condenser and coil problem solved starts every time must have gotten a bad condenser and or coil thanks for your help guys. jim s.
05-21-2016, 06:22 AM | #5 |
Re: Engine trouble
