Old 05-13-2016, 10:20 AM   #1
AlfinCT
Default Rust Remover Pasivation
After yiu use Evapo-Rust , el;ectrolysis or other methods to strip rust how do you passivate the surface without paintin or priming to keep it from rerusting while you work on the piece. Thanks.
AlfinCT is offline   Reply With Quote
Old 05-13-2016, 10:23 AM   #2
Rowdy
Default Re: Rust Remover Pasivation
A light coat of ATF works well. Easily removed with Prepsol or simular metel cleaner later before painting. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-13-2016, 10:57 AM   #3
Dennis Pereira
Dennis Pereira's Avatar
phosphoric acid solution will keep your cleaned metal from flash rusting . I have sandblasted parts hanging in dry storage that I treated for a couple of years that look great . Just waiting on me to finish body work .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 05-13-2016, 11:51 AM   #4
captndan
captndan's Avatar
Electrolysis removes rust temporarily and the parts will flash rust if not protected. Phosphoric acid changes iron oxide (rust) to iron phosphate an inert substance. Usually a primer is not needed. Can't speak for Evaporust.
captndan is offline   Reply With Quote
Old 05-13-2016, 12:41 PM   #5
Oldbluoval
Oldbluoval's Avatar
Wow
Wish I knew what passivate meant! :-)
Wd-40 works for awhile. Then I scrub down with comet and water when ready to paint/prime. Can also use thinner and wipe down
Then prime immediately when dry
Old 05-13-2016, 01:01 PM   #6
H. L. Chauvin
Passivate: Sounds like a term heard very often and used to inform people that when they get a tax increase, they will be able to afford eating out every night, and be able put more money in their savings accounts.
H. L. Chauvin is offline   Reply With Quote
Old 05-13-2016, 01:01 PM   #7
J Franklin
J Franklin's Avatar
Try OSPHO, I have had sandblasted fenders hold rust free for a year in the garage after an application of OSPHO.
J Franklin is online now   Reply With Quote
Old 05-13-2016, 01:12 PM   #8
CarlG
CarlG's Avatar
Wiki sez:
As a technique, passivation is the use of a light coat of a protective material, such as metal oxide, to create a shell against corrosion. Passivation can occur only in certain conditions, and is used in microelectronics to enhance silicon.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-13-2016, 01:23 PM   #9
J Franklin
J Franklin's Avatar
They tried passivation in Vietnam but it did not work.
Old 05-13-2016, 04:42 PM   #10
pgerhardt
pgerhardt's Avatar
Originally Posted by forever4 View Post
My experience with both evaporust and electrolysis (carbon Anode) is that no after treatment is needed or beneficial. After a hot water rinse and dry, the parts will not rerust unless later exposed to water or high humidity. I leave them be until ready for paint.
I also do not like using ospho generally.
That might work in Arizona, but I can guarantee that here in New England, or anywhere on the coast you will get rust (unless you have climate controlled storage). My new steel fenders (stored inside) started showing flash rust within one month. I used OSPHO and a scotch bright pad to completely remove it before epoxy priming both of them. NOW they are safe for any amount of storage.
pgerhardt is offline   Reply With Quote
Old 05-13-2016, 04:51 PM   #11
Willie Krash
Willie Krash's Avatar
As in a longer wrench provides enough purchase to turn a tight bolt?
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 05-13-2016, 06:19 PM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I couldn't PASSIVATE my Dog, when he wuz doin' a WOLF like SNARL at a stranger, at the door!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-13-2016, 08:02 PM   #13
pgerhardt
pgerhardt's Avatar
I was also specifically referring to parts which have undergone electrolysis or evaporust, not new sheet metal or sandblasted items, for example.
Well that may be possible. Evaporust leaves a dark grey coating that seems to be pretty inert. However if in your effort to get a very clean part, you have scrubbed some of it away, rust will move right in! Your safest path is to epoxy prime all bare metal. Then you can relax and take your time!
Old 05-13-2016, 08:26 PM   #14
updraught
updraught's Avatar
I've got some parts like this but I'm unsure whether it is a good idea to use epoxy paint over it?
updraught is offline   Reply With Quote
Old 05-13-2016, 08:29 PM   #15
Mike V. Florida
Mike V. Florida's Avatar
It's held back the rust for several years in the humid Florida.
Old 05-13-2016, 08:31 PM   #16
Wick
Wick's Avatar
I use oxalic acid to remove rust,then rinse,scrub,rinse,dry. If I don't prime the part then I put a coat of cosmoline on it.
Wick is offline   Reply With Quote
Old 05-14-2016, 11:52 AM   #17
BILL WILLIAMSON
I cleaned Minervas' Zenith in T.S.P, old paint fell off, BUT after rinsing it, that sucker rusted in my hand! Dunked it & rinsed it 3 times, SAME thing!!
Dried it off, sprayed it with Rustoleum, in the oven @ 200 degrees & it looked SUPERB !
The carb ended up on Jack Scotts' pickup, he passed away, the truck was sold & the carb paint still looked GOOD.
Bill W.
Old 05-14-2016, 12:30 PM   #18
H. L. Chauvin
Another Definition:
Pasivation: A message from the control tower after reporting that your parachute failed to open.
Old 05-14-2016, 02:07 PM   #19
BILL WILLIAMSON
Another Definition:
A MEMORIAL, "BILLS' CRATER"
Bill Squish
Old 05-14-2016, 02:58 PM   #20
Dollar Bill
Dollar Bill's Avatar
Plus 1 for phosphoric acid. Spray it on and let it sit for a few minutes then wipe dry with a paper towel. When you're ready to paint, scuff with scotchbrite pad, wipe down with prep-sol and fire away.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
