I swear there was something posted on here recently about leaking jet plug in the fuel bowl, but I can't seem to find it doing a search. Recently rebuilt a 94 with Charlie's help on the throttle shaft. The carb starts and runs great, but there is a small fuel weep around the one of the jet plugs in the fuel bowl. The gaskets are new, all the surface look good, what should I be looking for ? Thank you Fordbrainers.
Some of the new production gaskets I have seen have a rough surface that I needed to sand smooth with fine sandpaper-- I used 400 grit
Russ,
Those leaks are a pain. On my full rebuilds if I get a weeper I use Delrin gaskets that I make. Email me your address and I'll shoot some to you. Charlie ny [email protected] Last edited by Charlie ny; 05-07-2016 at 08:01 AM. Reason: changed shot to shoot |
Thank you for your responses. Nice to know it may not be the casting or plugs, but something as simple as a gaskets.
Replaced the gasket, and used a little Mercruiser "Perfect Seal" on the both sides of the gasket. No more weeping. Perfect seal is gasoline resistant, and I have used in marine applications you years. Thank you once again to all the Fordbrainers. |
