Old 05-06-2016, 12:08 PM   #1
ryanheacox
ryanheacox's Avatar
Default Mechanical Engineering Senior Project
Gentlemen,
I will be doing my senior project next fall and have been brainstorming ideas. I thought it might be fun to do something related to my Model A.
The two ideas I've had so far are to design a 4-speed OD transmission with better ratios as a direct bolt in replacement. I know Mitchell already makes a modern synchronized 3-speed but it's just one idea.
The second idea was to develop an automatic advance system. All I'm aware of that currently exists is the nu-rex kit and the electronic conversion. I was thinking maybe develop a vacuum advance setup?
As fellow members of the hobby, I'd love to hear your input. What other ideas could I consider? What other aspects of the car can be improved?
Thanks.
Old 05-06-2016, 12:55 PM   #2
30ccpickup
30ccpickup's Avatar
Default Re: Mechanical Engineering Senior Project
How about a machine that straightens Model A wheels.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 05-06-2016, 12:59 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
That machine has already been invented, ...it's called a torch!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-06-2016, 01:03 PM   #4
C26Pinelake
Your two ideas so far are take offs on apparatus that has already been designed. Not very innovative! Wayne
C26Pinelake is offline   Reply With Quote
Old 05-06-2016, 01:31 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by ryanheacox View Post
Gentlemen,
The two ideas I've had so far are to design a 4-speed OD transmission with better ratios as a direct bolt in replacement. I know Mitchell already makes a modern synchronized 3-speed but it's just one idea. Thanks.
We've already re-invented something pretty close for a V8......it's a re-configured and SHORTENED Camaro T5 5-speed (4 plus O/D) with wonderfully-close-ratio gearset (2.95 1st gear), that'll bolt-together using virtually ALL Borg-Warner factory parts, except for a simple 23-spline adapter, and a simple home-made, 1/2"-thick aluminum torque tube clamshell adapter plate. Take a peek below. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-06-2016, 04:47 PM   #6
Ian Curtis
Ian Curtis's Avatar
I've always thought it would be fun to do an instrumented speedster. Probably because I'm an engineer & thus a dork, I'd love to be able to look at & record fuel flow, coolant temp, RPM, brake temp, "g"s, advance, etc. The juxtaposition would be great if you could do a good job hiding all the instrumentation wiring, and then pull out an iPad to see how your performance looked.
I've always wondered what Ford's testing setup looked like back in the day, or maybe it was just mostly qualitative?
Ian Curtis is offline   Reply With Quote
Old 05-06-2016, 05:03 PM   #7
Cool Hand Lurker
Cool Hand Lurker's Avatar
How about a fuel injection system that uses the stock manifolds and the updraft Zenith carb body? Make it look like nothing has been changed too. Easy, eh?
Cool Hand Lurker is offline   Reply With Quote
Old 05-06-2016, 05:41 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
Climate control system (heat and Ac) integrated into the dash, tucked up almost out of sight nearly between the firewall and gas tank, with outlets and defrost integrated into the dash rail---- condenser under the car--- flywheel generater running inverter and electric compresser---- with power outlet to power house if needed--- perhaps 5 KW
Old 05-07-2016, 08:42 AM   #9
freak
freak's Avatar
Make a decent headlight socket/connector. You'd sell 10's of thousands of them.
freak is offline   Reply With Quote
Old 05-07-2016, 08:58 AM   #10
pgerhardt
pgerhardt's Avatar
You have gotten many Fantasy suggestions. If you go with your own idea of a bolt on 4 speed transmission I volunteer to test it out for you!
pgerhardt is offline   Reply With Quote
Old 05-07-2016, 09:17 AM   #11
freak
freak's Avatar
Who sells one? The ones I've ordered from Snyders are poor quality,
Old 05-07-2016, 10:06 AM   #12
freak
freak's Avatar
All the sellers list them as "fair" quality. I could post a number of pics detailing the differences between originals and these replacements. The biggest problem is that the pins are very sloppy and tend to all short together.
Old 05-07-2016, 10:44 AM   #13
freak
freak's Avatar
What site is that from?
Old 05-07-2016, 10:46 AM   #14
freak
freak's Avatar
I found it. That's not the part I'm talking about. This is it...
https://www.brattons.com/catalog/hea...t-sockets.html
Old 05-07-2016, 10:56 AM   #15
duke36
Come up with front and rear crankshaft seals that work / have some longevity but that can be replaced without removing the engine, etc.. You could get a PhD out of this exercise!!
Old 05-07-2016, 01:56 PM   #16
Flathead
Flathead's Avatar
Re-design the internals of the two tooth steering box for all roller operation. The benefits of the F-100 style box but stock looking. How about an A style Zenith with more CFM for modified motors that want to look stock. I guess the theme here is "stock looking"
Flathead is offline   Reply With Quote
Old 05-07-2016, 01:58 PM   #17
freak
freak's Avatar
Are you actually going to make something or just design something?
Old 05-07-2016, 09:24 PM   #18
tbirdtbird
'along the lines of automatic advance system'
I am not familiar w/ the Nurex system.
The FSI electronic dizzy has centrifugal advance only.
As you know in the 50s-60s dizzies were developed with both centrif and vacuum advance, which is the best of both worlds.
To me a super project would be to adapt a Type 2 VW beetle dizzy ('71 and later) to an A, since that dizzy had both centrif and vacuum. Then you could really dial in your timing. It may not matter much if your engine is all stock, but once you start hanging performance goodies on there such as HC heads, better cams, larger intakes, etc etc your timing ends up so far from ideal it is ridiculous. And most ppl with these types of goodies end up with too much advance, or too soon, and begin to trash mains.
It would help if you had access to a Sun distributor machine and a dyno; but the project could still happen with some old fashioned seat-of-the-pants testing
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-07-2016, 11:15 PM   #19
Mike V. Florida
Mike V. Florida's Avatar
Sounds to me that he just needs a design for the class project and he figures if he is going to go through all that trouble he might do something he can make money on later. I suggest that he takes a close look at the class description as I know some colleges reserve the right to retain any ideas as their own.
Old 05-08-2016, 04:01 AM   #20
Mitch//pa
I have not ever had a problem with those shorting out at the bulb ends or the connector ends using the brattons parts I had mentioned. I deleted all my other posts cause I felt the OP's topic was some what hijacked... Sorry for that
When they mention marginal quality I don't believe they are talking about shorting.
