If anyone knows of or has a Ford adaptor to attach a 1937 3- speed transmission to an 8 BA I would appreciate the information. I checked with Speedway and they say that Ford made one but there is no aftermarket version. Any help is appreciated. 0405161249.jpg
0405161249a.jpg 0405161301.jpg |
1948-1952 Ford V8 trucks and 1949-1950 Mercury cars had a bell housing that will do what you want to do. Be sure to get the correct starter plate with it.
You are missing the stock bellhousing that bolts to the block. I looked on eBay and found three.
Respecting and Resurrecting Ford Model A's. |
It is a steel stamped ring, should be easy to locate one. In the past there were also aftermarket alum. Ones.
Check out Wilcap.com, there is a lot of information and pictures on their site.
http://www.wilcap.com/flathead.html
These are the stock bellhousings used on the 1949-1953 Ford truck (cast iron) and the 1949-1953 Mercury (stamped steel). These "convert" the 8BA block to the 59A bolt pattern. The use of the correct starter plate is critical to the function of these bellhousings. |
I have a couple of each type that I would be willing to let go cheap. Unfortunately, I am away from my shop for a few more weeks. If you can't find anything in the interim, get back to me.
Thank you for the information. One of the attached photos shows the bell housing that came on the engine. I will check ebay to see what is listed. I want to ensure that I get the correct one with the correct starter cover. Are they labeled in any way so I can tell? Thank you for all of the suggestions.
#10 | |
![]() Quote:
http://www.ebay.com/itm/1948-1949-19...r#ht_173wt_867 ![]() |
WOW! Maybe I should reconsider "Let go cheap"?
I don't see anyway that will sell for that price. The hogsheads were selling for $100 to $150, know way the adapter ring is worth that much. Haven't followed them, but I would think more like $50 to $75.
#13 | |
![]() Quote:
#14 |
If all else fails, call Ray Helgers, 401 636 4849, he has a building full of them, and knows what works with what. Can't beat Ray's knowledge, and the price is always very reasonable.
#15 | |
![]() Quote:
#16 | |
![]() Quote:
#17 |
Wilcap and VanPelt are both sites with a lot of good information on bellhousings and starter plates.
#18 |
That eBay price isn't all that bad. We sell them for a bit more. Not that I'm trying to rip anyone off either. Those cast iron adapters have to be checked carefully for cracks. Many times you don't see the crack til you've spent the time cleaning the piece thoroughly. Plus, there's always more cast adapters than the matching starter plates. The value is in the pair.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
#19 |
I think the cast ones were for the 11 inch clutch originally but they will work for the smaller ones just fine. Definitely a truck part for sure. Some of the Mercury ones have a flange on the starter plate that bolts to the aft bottom edge of the oil pan but this can be removed if not needed. If you see one with this then you can tell it's from a Mercury car.
#20 |
i've got one a couple hours north of you. will take trade on a good 40 style front brake drum. send a pm if you like
