mine doesn't it comes from the port on carb above throttle plate, manifold vacuum is for the loadamatic dist, the advance works just the opposite of vacuum advance
#2 | ||
![]() Quote:
This is not related to the HEI, but the load-a-matic does not use manifold vacuum (or ported vacuum either for that matter), it requires a specific carb designed to work with it.
