#21 |
When I think of using a HIGH compression head, I think of those SMALL rod & main bearings!!!
For example: Datsun inline 6 cylinder engines have HUGE mains & rod journals & was one of the few GAS engines, that were converted to HIGH COMPRESSION Diesel engines & survived AMAZINGLY WELL!! Bill W.
#22 | |
#23 |
I was wondering the same thing?
No need to change wheels for overdrive. |
#24 |
Well first, a lower center of gravity and better stability with 16" wheels and wider radials. I find the bias ply balloon tires of the day a little scary at 60 (my max speed downhill). The folk in our club prefer 16" radials for better handling. I never thought H Ford intended the A for anything more than cruising at 55 or less.
... prosperity is not the product of charity but of industry - HENRY FORD |
#25 |
#26 |
#27 | |
and no one in the caravan is to let the guy behind him drift back much. So we felt like the weak link.What I'm going to suggest is to have two separate caravans... one for the Mod Squad, and one for the more stock crowd.The worst that can happen is they'll get to the beer first
#28 | |
Nevertheless, I don't have to "keep up with the Jones's". Them Jones's are probably in hock up to their cowl lights anyway.
#29 | |
I'm going to skip to the end here and not read every post. I don't think I have to because I'm sure they all say the same thing. those two guys are full of it. Even if your engine is in poor condition our "high compression" (HC)heads for the engines ain't that high. The 90-125hp V8 engines had 6.8 to 7.2 heads on babbit. The HC heads we have for our A's are less then or equal to that.
#30 | |
Yes, I realize the Model A heads available are not REALLY very high compression, even at 7.0 . I will probably check into a 6.0. That, along with the B-cam, new pistons, rings and valves should be a big improvement. I have a good mind to leave my flywheel alone. My crankshaft is not balanced, and thus matches well with it. I'm not interested in rabbit jumps at the stoplight anyway. It's too late for me to try to impress the ladies
#31 |
A high compression head won't make the car go any faster. It will increase the torque the engine produces and make hills flatten out. It will take off better and climb hills like a billy goat but won't go faster. I have run heads up to 8-1 compression on a race car with no problems. I did sell that engine several years ago and it is still being used in a tour car regularly. He uses a Snyder 5.5-1 head. Denis4X4 is correct about timing and not running too much.
I would also steer clear of the 2 guys that told you not to run one. They are fools.
http://www.model-a-ford-4bangers.com/ |
#32 |
I have a 1930 Town Sedan, and almost 10 years ago, right after I bought it (fully restored), I added the 5.5 HC head, Mitchell OD, lightened flywheel and V-8 clutch, and cast iron brake drums. I kept the 19" wheels and Goodyear tires, everything else pretty much stock. I have been on two long tours in California, on both 101 and I-5 up to Yosemite and Hearst Castle. I also drive on shorter tours, on our local freeways, usually at 60 mph. I have absolutely no regrets over any of these mods, and have no issues on controlling my A at speed, and see no need to convert to 16" wheels. I feel that both the HC head and the Mitchell work together great in a car built for some touring and freeway driving. Here in S. California, it is very limiting not to be able to use the freeways at least some of the time.
#33 | |
#34 | |
But I get excited every time I try to talk myself (and wifey) into the O/D. If I'm going to all this trouble and expense, I want her to be a smooth and fun ride for a long time. I expect Bonnie to outlive me.
#35 |
'pick his brain about lightening the flywheel some'
so you are gonna get a counterweighted crank then
'31 180A |
#36 |
Actually, the stock (heavy) flywheel will get you across the intersection the quickest! Rev to about 2,000 RPM and pop the clutch. All that stored energy will shoot you across the intersection in a rapid manner!
#37 |
Well, I know I said I'd talk to John about it. I just want to know all the pro's and con's to both schools of thought. If there's no real advantage to lightening the flywheel other than getting up to speed faster, I'm leaning much more to leave it as originally engineered. Most in the club have lightened theirs, but it doesn't mean I have to. They like to modernize a bit too much for me.
#38 | |
#39 |
"Crystallizing the babbitt" is not realistic. 5:1, 5.5:1, 6:1 and 7:1 compression cylinder heads have been around since the Model T was new, and there is no stigma attached to their sensible use. I have been running a 5.5:1 cylinder head for many years without issue.
Bob Bidonde |
#40 |
As mentioned many times here, it is not the high compression head that is the problem. I have been running a 7:1 head with babbit for 9,000 miles with out any problems, or "crystalizing of the bearings"
