Old 03-02-2016, 06:28 AM   #10
funrunr
funrunr's Avatar
Default Re: Bad day, found a crack....
Build a test stand with a radiator and run it, it will tell you what it needs. You already know it needs repair, why not see if it will run as is until you can pay to have complete rebuild/repair. The most you will be out is a set of head gaskets. Good luck!
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
