02-17-2016, 07:25 AM | #1 |
Need trans help
Hey folks. My brother rebuilding an FOM trans for his '56, needs a new or good used front converter turbine for it.
The trans is out of my old parts car - a '56 Fairlane originally with a 312, code on the trans case tag is PAR-7003-F2 and based on what I'm seeing in the parts book the # for the turbine is B7A-7920-B. I posted a pic of the parts book illustration showing the turbine. If anyone has or knows a source for one please let me know? He has some other bird-dog searches out but last time I talked to him, he hasn't had much luck locating one yet. I haven't put it on the swap-meet place yet but if no luck in a few days will do so. Thanks! |
02-17-2016, 01:07 PM | #2 |
Re: Need trans help
Have you tried these guy's ? http://www.greensalescompany.com/ They deal in N.O.S. Parts, and have many hard to find items. If they do not have it they may be able to recommend where else to look.
02-17-2016, 03:48 PM | #3 | |
Re: Need trans help
Unfortunately they didn't have the turbine. If all else fails he might take it to his local machine shop guy to see if it can be salvaged. But still looking so if anyone can assist, LMK. Thanks. |
02-17-2016, 08:36 PM | #4 |
Re: Need trans help
Have you tried ebay? They have almost everything.
Here is some possible sources Adrian 570-709-0823 PA. Lots of Tbird parts Tony's Classics 515-263-3606 Iowa By the way - they are called converters.
02-17-2016, 11:02 PM | #5 |
Re: Need trans help
Try Hills thunderbird in Racine OH. They should have a converter for your 56. 1-800-562-1955
02-18-2016, 04:21 AM | #6 | ||
Re: Need trans help
BTW - Paul, the turbine (base # 7920) is an internal component of the converter assembly (base # 7902). This particular converter can be disassembled and repaired or rebuilt, unlike many converters that cannot be disassembled. He didn't need the complete assembly, only the turbine as shown in the parts illustration. Thanks to all for the help. Last edited by raceron1120; 02-18-2016 at 12:31 PM. |
