What ever you do I would not suggest doing any grinding etc... Something is amiss causing your issues. I suspect as Bob said your having the light switch body in place is causing your problem. Take it off and install the clip 1st.
Dave / Lincoln Nebraska |
Excellent advice.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
