Installing new engine in car .The front of engine is off center 3/16 of a inch. What is best way to correct this problem Thanks John
Loosen the rear mounts and give it a yank. Retighten the rear mounts.
I will try that Thanks John
Once you drive it,it'll probably move more than that! Happy Holidays!!
www.whidbeymodelaclub.com |
was the old engine ok? Is the mount hole in the frame wore on one side? If previous posts don't solve the problem, there's a chance your frame is tweeked.
