Another interesting set of codes that one may find on the chassis is in relation to the number or Rear Spring Leaves that were originally used when the chassis was assembled. It has been thought that these stampings were used to correlate the number of leaves in the rear spring with a particular body style for which was going to be assembled to the chassis.
Mr. Carl Biederman from Anoka, Minnesota had found several of these codes on various Model A Ford chassis with some letters followed by a number for which was stamped into the rear areas of the vehicle. The areas for which Mr. Biederman has found these codes are as follows: 1). Rear end axle housings; 2). Top of the rear frame cross member and 3). The right rear corner of the rear frame cross member. Such as "R7" "C8" "T0". The following list may be incomplete and may not have been implemented by all the assembly plants for all years. STAMPING BODY STYLE REAR SPRING LEAVES Roadster Seven (7) leaves C8 Coupe Eight (8) leaves OCPU0 Open Cab Pickup Ten (10) leaves T0 Tudor Ten (10) leaves TS0 Town Sedan Ten (10) leaves FD0 Fordor Ten (10) leaves Does anyone have any photos of these stampings? Need a few for an article. Thanks. Pluck |
![]() ![]() Here's one that is still a mystery. Is this a mistake, or is it an option? The "8" appears to be upside down, but that isn't the question. Since the "R" stands for Roadster and Roadsters had a 7 leaf rear spring, why is this stamped with an "8"? Could it be that an 8 leaf rear spring was an option, maybe being the spring of choice if the car came with a rumble seat? Or, was the "R" a mistake and it should have been a "P" for a Phaeton? |
![]() ![]() Here's another picture of a spring code on my 9-27-28 Phaeton. Why is the "P" so small? |
Pluck,
Look at Ahooga and you will see another code, which I've never seen before. Richard WV posted a good picture of C S 0 on his Convertable Sedan with 10 leaf spring. I hope he posts the body number to ID the assembly plant. |
This stamping is on an unmolested chassi. The body was a 1930 or 1931 nevere messed with coupe. Body went on a hotrod and chassi followed me home.
Ahhhhh! Fiddle. I dont know how to post pix on this site. I will send or post pix when I can learn how. Meantime the code is a D C on the right rear crossmsmber - same position as pictures above. |
My June of '29 Twin Cities 155A Town Sedan has a large "TS" stamped on the rear cross member. Gar Williams
The answer just might be in the Twin Cities Ford Assembly Plant's Service Letters if one were ever to find a set!
Pluck |
Didn't someone say there's no such Model A as a "Doctor's Coupe".
Well, Ken has it stamped into his rear crossmember! ![]() |
Registered User
could it be Deluxe Coupe??
#13 |
I checked our four A's and none of them had any stamps in the rear crossmember.
However, our unrestored 1929 Fordor had a wired on tag attached to the left rear crossmember through the body mounting bolt hole. You can see what's left of the tag in the attached photos. I suspect this tag served a similar purpose as the crossmember stamps, but of course I'm just speculating. I sure wish there had been more of the tag left when we bought the car. I was dry and brittle, and falling apart just to the touch. Dave Lopes |
#14 |
Dave,
That's very interesting about the " tag ", are ALL your cars west coast cars? Take care, Dudley |
#15 |
I like "Doctors Coupe" better that "Deluxe Coupe". Makes for better stories, but when I get thru building on it "Dumb Contraption" may better suit. Ken
#16 |
Off Track from Original Post by Steve
Dudley, The Fordor I post a lot about was bought new in New Rochelle, New York, with a deposit check written on July 9, 1929, and a balance check written on July 18, 1929. The firewall date is June 28, 1929. It didn't come to California until 1967. I know our Phaeton resided in Oregon from the late fifties until I bought it in pieces in 1990 and brought it to California. No other history. Our Special Coupe I have no history other than the prior owner who I bought it from in 1974, lived in Southern California. I bought our 1930 Standard Coupe in 1969, from an uncle, who bought it in Nevada a few months before, with no known history. It is neat when we have some history of our cars, but with the exception of the Fordor, I have very little. Back on Track to Steve's Original Post; That's another reason why I like threads like this one so much. Another "Tip o' the Hat to Mr. Plucker for continuing the detail research. (And many other good people) Dave Lopes |
#17 |
Sorry for bringing this thread back from the dead but here it goes. Found this on my frame before I started sand blasting it.
IMG_02351.jpg |
#18 | |
![]() Quote:
Have you checked the body number? Does it start with TC, which stands for TWIN CITIES. |
