Old 10-10-2015, 11:22 AM   #1
oneoldtruckguy
Default 1957 Ford 9" rear end
Thinking about putting a 9" rear end in my 1950 F1. I found a nice 9" rear end out of a 1957 Ford pass. car with an automatic. Does anyone know what the rear end ratio options were in this car? I have a 3.78 or close now but would like to go higher for more road speed and lower rpm. I am in the process of changing from a 4 speed to a rebuilt 3 speed top loader also.
oneoldtruckguy is offline   Reply With Quote
Old 10-10-2015, 11:26 AM   #2
ponymare
Default Re: 1957 Ford 9" rear end
Most likely it would be 3.00, but to use a car rear end, the spring mounting pads will need to be welded on the other side, and maybe moved farther apart.
ponymare is offline   Reply With Quote
Old 10-10-2015, 12:10 PM   #3
craig
Depends on what engine the car had. I had a 6 with a straight stick that had 3.89's, a 292 with fordo that had 3.23's and another with 3.10's behind a 312 with fordo.
Lock up one axle, turn the free axle, count the pinion revolutions and figure the ratio
craig is offline   Reply With Quote
Old 10-10-2015, 12:58 PM   #4
5851a
If you use a housing from a pickup with a 9 inch before 1973 it should be the same width and bolt in. I think from 73 to 86 will bolt in but be wider.
5851a is offline   Reply With Quote
Old 10-10-2015, 04:23 PM   #5
roadster36
I have used quite of few of the '57 rear-end's in various projects. Almost all had the 3:89's as previously posted by Craig. They work good with a T-5.
roadster36 is offline   Reply With Quote
Old 10-11-2015, 07:32 PM   #6
paul2748
paul2748's Avatar
57 Automatic rears had around a 3.20 something or possibly a 3.10. The standard and O/d trans' had lower ratios (higher numericaly)
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-11-2015, 09:52 PM   #7
Ford blue blood
Ford blue blood's Avatar
The 300 Custom I parted (rusted in half) had a 3.56, it was a factory air car with a 292/auto. My Ranchero has a 3.56 also, it was a 292/manual, and my Retractable is a 292/auto with a 3.56 as well. A Ranchwagon I had was a 6/manual with a 3.89.
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 10-12-2015, 05:32 PM   #8
WestCoast
rear ratios run from 2:50 to 4:30, basically the only difference in the rears is some had 31 splines and some had 28 axle splines, the 31 spline axles can be shortened, there should be a tag on the rear housing having the ratio info , what ratio do you want? 3:50, 3:25, 3:00, 2:75, 2:50, these are all auto,trans rear ratio's, take a pretty stout engine to run one of these, well maybe not the 3:50 or 3:25
WestCoast is offline   Reply With Quote
Old 10-12-2015, 06:04 PM   #9
Alaska Jim
Alaska Jim's Avatar
It all depends on the transmission gear ratios, as to what rear ratio will work best, this applies to automatics as well as manual transmissions. that is why there are so many different ratios. not all automatic's or manual are the same ratio in every gear.--Jim
Alaska Jim is offline   Reply With Quote
Old 10-12-2015, 06:30 PM   #10
Ole Don
Ole Don's Avatar
If you have to go out and spend money for a three speed, think about spending a bit more and look in to a five speed. They are Soooo, nice.
Ole Don is offline   Reply With Quote
Old 10-12-2015, 10:46 PM   #11
WestCoast
Jim, auto trans have a lot of different gear ratio's in the lower gears, but they all have 1 to 1 final drive, except the over drive trans
Old 10-13-2015, 12:22 AM   #12
Alaska Jim
Alaska Jim's Avatar
Yes, that is true. thanks for clarifying that.
Old 10-13-2015, 06:14 AM   #13
GreenMonster48
GreenMonster48's Avatar
1957-72 Ford 1/2 ton pickup rear ends are basically a bolt in to the 1948-52 F-1s. I'd hold out for one of those. They're still plentiful and offer a wide range of ratios and have the same wheel bolt pattern.
GreenMonster48 is offline   Reply With Quote
Old 10-13-2015, 03:38 PM   #14
WestCoast
in my experience the p/u rear ratios were kinda low, 3:73 or close to that, 4 wheel drives were even lower
Old 10-14-2015, 11:29 AM   #15
GreenMonster48
I've seen a bunch of 302 powered F100's with 3.25 ratios. You're right though, you could probably run through a field of 3.70's before finding a tall one.
Old 10-19-2015, 11:53 AM   #16
hardlyrider
hardlyrider's Avatar
Here is a link with some info that might help you identify the ratio if that rear end was the original in the '57.
http://1957ford.com/asp/gallery.aspx...=1&catdetid=29
hardlyrider is offline   Reply With Quote
Old 10-28-2015, 10:51 AM   #17
George/Maine
George/Maine's Avatar
The truck rearend would be better 57 to 72 the car length is about 4" short ,not wide enough.
George/Maine is offline   Reply With Quote
