Old 10-26-2015, 12:58 PM   #1
Brianfrench65
Brianfrench65's Avatar
Default PPG Concept storage
I have about a quart of one color and about 2 1/2 quarts of another color, in 1 gallon cans. It is PPG Concept, acrylic urethane paint. I would like to filter and pour into pint cans, hoping that it will last better. What can I use for a thinner, to slightly thin the paint, and not compromise the paint?
Brian French; 1930 Briggs Town Sedan
Brianfrench65 is offline   Reply With Quote
Old 10-26-2015, 01:26 PM   #2
harleytoprock
Default Re: PPG Concept storage
I've heard that thinned paint should not be saved. I would just fill cans with least amount of air space and store in a cool place. Save the filtering for when you use the paint.
harleytoprock is offline   Reply With Quote
Old 10-26-2015, 01:33 PM   #3
Brianfrench65
Awesome, thank you.
Old 10-26-2015, 01:39 PM   #4
Oldbluoval
Oldbluoval's Avatar
I always store paint cans up-side-down. Making sure I apped the lids down of course.
The reason.....50 years ago, a guy that trained me in body work told me to!
I suppose it makes a better seal. Also, as little of air left in the can the better as already stated.
Old 10-26-2015, 01:45 PM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Brian, thinned paint really won't hurt anything and I suspect what Harleytoprock was pointing out deals more with trying to save catalyzed paint (paint that has hardener mixed in). Fill the pint cans where there is minimal air inside, and you will be fine.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-26-2015, 01:49 PM   #6
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have stored less than full quarts cans of PPG concept paint for over 13 years. I have used the paint periodically over the last 13 years for touch up jobs. I have had no issues with using the stored paint.
Dick M is offline   Reply With Quote
Old 10-26-2015, 01:59 PM   #7
J Franklin
J Franklin's Avatar
Even mixed catalyzed paint can be saved quite a few days in the refrigerator. A friend showed me this.
Old 10-26-2015, 02:00 PM   #8
Brianfrench65
Thank you all, very much. I really appreciate the wisdom of the members.
Thank you.
Old 10-26-2015, 03:51 PM   #9
Keith True
Keith True's Avatar
I was given a few dozen gallons of Dupont urethane(Imron)years ago.It was from a truck fleet that used it on their frames and axles.The insurance company told them,no more paint on the premises.They had been letting the paint work out for a few years anyway,so it was given to me.It is all dated 1977-78.I never planned to use it on anything critical,but I used some on one Model A in 1988,another in about 98,and on my roadster pickup about 8 years ago.It seems fine.I used the rest of an opened gallon on my Dodge pickup frame last week,not sure if it was one opened 25 years ago or 8 years ago.It acts like fresh paint.The activator is all from the same era,it pours out of the can kind of golden looking,that may be what it is supposed to be.I don't know if the solids separate out while sitting,I never think to put a stick in it before I shake it,but two minutes of shaking is plenty.
Old 10-26-2015, 04:43 PM   #10
MikeK
MikeK's Avatar
Glass marbles! I was given a 12 year old quart of color in a can with plenty of wiped drips on the outside. The guy that gave it to me said to be careful pouring it. The can contained only about 1/2 paint plus marbles to take up the air space inside! When I opened it the can was full to the very top and the paint was like new. Of course, marbles were cheaper 12 years ago.
MikeK is offline   Reply With Quote
Old 10-26-2015, 06:57 PM   #11
jw hash
jw hash's Avatar
it will not harm concept to thin it. use any one of the PPG DT thinners to thin it. first thing first make sure you stir it up good so you end up with the same color later on.
jw hash is offline   Reply With Quote
Old 10-26-2015, 07:00 PM   #12
Russ/40
Russ/40's Avatar
Don't know if it's considered ok, but I save left over paint in glass quart jars. It stays fresh, and there is no worry about cans sealing. I don't trust the seal on a paint can when its been opened and closed several times.
Old 10-26-2015, 07:03 PM   #13
Bill's Auto Works
Bill's Auto Works's Avatar
All great tips! I will add one of my own, as far as I am concerned not letting it freeze is the most important thing other than making sure the lid is fully secure. I have many thousands of dollars worth of paint in my mixing room & I have my building set to 50 degrees at all times I am not in there.
Your QUALITY Ford Barn Transporter- Open or Enclosed.
Bill's Auto Works Est. 1983 & Still Going Strong!
1955 Chevy Altered W.B. Gasser
1955 Nash Amb. Cust. Lemans
1964 Pontiac Grand Prix 2 DR HT
1966 Pontiac Catalina Conv
1966 AMC Ambassador DPL 2 DR HT
1966 AMC Ambassador Cust 2DR HT
1967 AMC Marlin
1967 Toronado
1973 Chevy Nova Full Chassis Car
1992 Jag XJS Conv
1992 Jag XJS 2 DR Coupe
2007 Cadillac XLR-V Supercharged Roadster
2008 Southern Customs Avalanche
Bill's Auto Works is offline   Reply With Quote
Old 10-26-2015, 07:39 PM   #14
J Franklin
J Franklin's Avatar
At what temp, do you thinks the solvent will freeze? - 300 degrees?
Old 10-26-2015, 07:42 PM   #15
glenn in camino
glenn in camino's Avatar
I think that the paint will store ok in full cans, but hardener should be refrigerated.
