Old 10-19-2015, 03:29 PM   #16
George/Maine
George/Maine's Avatar
Default Re: 47 brake problems
I always adjust the brakes first when done should have slide drag. Then make sure you have a returns spring on pedal. What I do is crack the bleeder little so to leak out and pump and see good puddle of fluid on ground don't let pedal go to floor and keep mc full, close the blender and do the same to other ones. Test drive
George/Maine is offline   Reply With Quote
