Looking at buying a basket 46 pickup. Title says 41 seller said state listed it wrong.
The number on the title is 1GA602. I believe the serial number is located on the passanger frame rail just in front of the firewall. I did not find any numbers on the frame could they be located somplace else? I would like to buy this truck but nervise about title saying 41 and truck being a 46. Thanks in advance. Terry |
Hi, I found my serial #s on the frame under the front left corner of the cab, not visable with cab on. Russ
Thanks Russ, what year is your truck?
I have a 1932 BB and a 1936 pick-up, also found them on my boss's 1940. hope this helps. Russ
Can some one decode this s/n 1GA602 ?
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm Kerby |
#7 | |
'41 and '42-7 pickups differ so much that the title tangle should be easy to decide.
A six cylinder '46 would have had the same G series engine as a six cylinder (first year available) 1941. The numbers following the engine designation were just the sequential number, and a '46 # would be MUCH higher than that. It is conceivable that the '41 title could have been from the 602nd 6 cylinder produced, as that was the inaugural year for the engine. Look farther forward for frame number, too...they can be as far up as the crossmember. Look at toe-board in cab for a slot with punch-out cover near center...I don't know the trucks, but passenger cars of this period had a tab there maybe 3/8" X 2" that could be bent up to allow a view of the serial on the bellhousing. And, as Jerry said, a quick census of your springs will tell you if the chassis is '41 or '46. |
1941 was the last year for the torque tube drive in the Comercial models (pick up). In 1942 they went to parallel leaf springs in the back to hold the open drive rear axle and allow for more gross weight advantages. The front parallel leaf springs were also a way to "beef" the comercial models up to haul heavier loads. It definitely did away with the wishbone designs.
The 1941 comercial also still looked like a 1940 model. A far cry from the "jail bar" look of the 1942 front end. Kerby Last edited by rotorwrench; 11-19-2010 at 03:47 PM. |
The serial number is on the drivers side of the frame in frount of the firewall. Take a wire brush to it and you will find it. Truck could be a 42-47, but you won't know for sure until you find the serial number. Hope you get the truck and get another jailbar back on the road...
Thank You You guy's are awsome!!
Terry |
My son has a 45,I'm curious as to what the serial number is on it.I've heard of 43s also,but not of 44s.
Milt/Las Vegas |
#13 |
Most of the "jailbar" pickups I've seen are 42,46, and 47's and very few 45's. I have never seen a 43 or 44 but I am sure some were made for wartime use and farm work.
#14 | |
Do the two serial numbers stamped further back on the frame hidden by the body have the star and prefix like the front number?
Milt/Las Vegas |
#15 |
I see on the list from vanpeltsales that the 42-46 6 cyl.numbers are consecutive but the v8s aren't which would mean all 43-45 were v8s or maybe held over 42s.
Milt/Las Vegas |
#16 |
An interesting twist according to vanpelt my 40 conv.has a 41 serial number.All 40s started out with I85,whereas 41s started with I85 but ended with I86.The car was a barn find with a very old title go figure.
Milt/Las Vegas |
#17 |
The 18 is the prefix denoting 221 engine series, so that is the same on all 221 Fords.
The numbers following the 18 are just a sequential number the change from 18-5 to 18-6 is just the number of 221 engines built climbing. The '32 designated as the first of the line carried the number 18-1. |
#18 | |
Milt/Las Vegas |
#19 |
That is just from the sequence of numbers growing, not a deliberate change in the prefix or style of the number. All 221's made for 1940 use were numbered from x to y, all 1941's from y+1 to z, etc. so that all 221's are on a list from 18-1 to the end of the line. Any particular number beginning with 5 will fall into a particular year range.
#20 | |
Milt/Las Vegas |
