Old 09-15-2015, 03:25 PM   #1
Bill S
Default Mounting a fuel cut off valve
I am installing a electric fuel pump with a manual fuel shut off valve. My question is those of you that installed a manual fuel shut off valve did you drill into the frame to mount it with bolts or use a epoxy to attach the mounting brackets. I glued two pieces of metal together with super glue and could not break them apart. But than would vibration break the bond of the super glue.
Thanks for any input.
Bill S is offline   Reply With Quote
Old 09-15-2015, 03:53 PM   #2
A bones
A bones's Avatar
Default Re: Mounting a fuel cut off valve
Mounted near the carb where you have an easy reach, and open view, it could stand on a metal line. If however you're thinking rear frame; and don't want to drill I'd would not go less than proper prep and J-B weld or PC7. That said my vote would be to mount it rigid with hardware to avoid future vibration troubles. IMHO
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 09-15-2015, 04:13 PM   #3
skidmarks
skidmarks's Avatar
Make a bracket that can be used with an existing bolt like a body bolt near the fuel line. Don't mount the valve near the exhaust pipe incase the valve decides to start leaking . Yes I have had manual valves go bad and leak around the handle.
skidmarks is offline   Reply With Quote
Old 09-15-2015, 05:38 PM   #4
f1builder
easier to just use a toggle switch.
f1builder is offline   Reply With Quote
Old 09-15-2015, 06:04 PM   #5
39topless
Soak that metal part, that you glued together, in gas for a little while and then check to see if it still holds together. I would guess it would not.
If you get in an accident and need to shut off the gas, will you be able too reach the mechanical valve before your car bursts into flames? Go with the advice from f1 builder.
39topless is offline   Reply With Quote
Old 09-16-2015, 09:25 AM   #6
19Fordy
19Fordy's Avatar
I soldered a radiator pet cock in the fuel line 15 years ago. It allows me to shut off the gas flow when I need to change one of the fuel filters or electric fuel pump. No bracket needed. Rubber donut keeps it from hitting the floor and also absorbs any vibration.
Old 09-16-2015, 08:26 PM   #7
41LjH
41LjH's Avatar
I agree with f1builder. My electric pump has a toggle switch. This allows for fuel shutoff and is easier that a valve. To change by carbs or filter just start the engine, turn off the toggle and wait for the engine to quit running.
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 09-16-2015, 08:38 PM   #8
36 CS
I installed cutoff valve directly to tank, then installed filter, and then installed electric fuel pump. That way if you replace the filter or elect. fuel pump,just cut off gas flow and replace. cutoff valve screws directly to tank and tank holds it in place. just my 2 cents
36 CS is offline   Reply With Quote
