Old 08-11-2015, 04:32 PM   #1
jetrod
Default Handy Dandy Toe In Tool
I've seen a host of ways to adjust the toe in for the front tires and all seem to fall short in one way or another, (chalkline, 2x4's, chains, angle irons, etc.) The pictures show the guage I made about 30 years ago and have alligned dozens of cars and the results have been excellent. It's made of 1x4 wood and takes about 15 minutes to make. (1-pc x 6'0--2 pc x 10" and 2 pc. x 14") Assemble as in the picture--make the 10" feet project below the 6'0 crossmember so the crossmsmber is a little above the floor--the 14" risers are spaced 55"apart and the tops are 16" above the floor. Mark a center line on one riser and attach a piece of measuring tape or ruler to the other riser. Now to use it! First;Jack the front end and place on jack stands (tires 1" off ground). Next align the front tires with the centerline of the car. (I eyeball them to line up with the rear tires, but many other ways will work, just try to get them close to straight) Now slide the guage under the car and line it up to the rear of the tires--make a mark on the tire on the control side (I use tape to make it easy) and make a mark on the ruler side and remember the dimention. Now move the guage to the front of the tire, rotate the tires to bring the tape in line withthe guage, set the control end on the mark on the tape and then read the ruler end. The difference in the readings indicate the amount of toe in or toe out, and it is easy to adjust the tie rod to make the adjustment. And that's it! I'm sure I'm not the only one to use this method but I've never seen it on the FB, so I thought---oh,oh!! PS I've done this with the tires on the ground and there is no difference, so I like the jackstands.
jetrod is offline   Reply With Quote
Old 08-11-2015, 05:56 PM   #2
bdave_mcc
bdave_mcc's Avatar
Default Re: Handy Dandy Toe In Tool
Good tool! one thing I was taught a while back was to jack up the wheels and use a something steady to hold a marking device or even just something sharp that will scratch a line onto the tire(I have used an old hacksaw blade with a point cut onto it) Hold the marking tool against the tire while being held steady on a jackstand or whatever and spin the tire to mark a straight line around the circumference of the tire. Use that line to measure off of. This will help compensate for any runout you may have in the wheel or tire assembly.
bdave_mcc is offline   Reply With Quote
Old 08-11-2015, 08:31 PM   #3
stewwolfe
stewwolfe's Avatar
What a simple way to handle toe in measurements and adjustment. The Old Dominion model A Ford Club will be the proud owner of this jig within the next couple of weeks.
'31 40B
'31 68C
stewwolfe is offline   Reply With Quote
Old 08-11-2015, 11:39 PM   #4
Fred S
Fred S's Avatar
I'm new to this, and a friend showed me marking a line on the spinning wheel method, and then we used a tape, to measure both sides. A two man operation, using the tape. This is a much simpler one man job. I think hinges could be used on the end boards, and bolts with wing nuts on the risers, allowing the whole thing to be folded up and stored flat. Thanks for sharing your invention.
Fred S is offline   Reply With Quote
Old 08-12-2015, 10:56 AM   #5
Fred K-OR
Fred K-OR's Avatar
Here is also doing the same thing with a little different construction. Did mine a year or so ago. It does work.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-12-2015, 12:37 PM   #6
hardtimes
hardtimes's Avatar
Yes, there is a 'host of ways', indeed.
Just did this job on my A. A fellow barner here made a simple such measuring tool....from a spring loaded curtain rod ! Real ingenious and simple to use and to store. Worked great too.
Old 08-12-2015, 01:14 PM   #7
Fullraceflathead
Fullraceflathead's Avatar
The Spring loaded Curtain Rod is still the most accurate and simple once you understand how and why it works IMO. It can even be used with slightly bent wheels.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 08-12-2015, 04:10 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
The only trouble I see is that if there is any looseness in the front end the measurement would be off when the wheels are on the ground.
Old 09-01-2015, 10:46 AM   #9
bunnyc
bunnyc's Avatar
jetrod: I built and used your tool on my Tudor. First reading was 9/16" toe-out! Now set to 1/16" toe -in. Thank you for posting.
bunnyc is offline   Reply With Quote
Old 09-01-2015, 12:07 PM   #10
burner31
burner31's Avatar
What's that other vehicle in the picture?
Hard to tell, but looks like a coupe.
Keith
Shawnee OK
'31 SW 160-B
Old 09-01-2015, 01:14 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Whatever method you use, the MAIN THING is to observe the tread wear, REGULARLY!-- IF it's SMOOTH, with NO signs of SCUFFING, from the outside in, or the inside out, & drives properly, YOU'RE GOOD TO GO.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-01-2015, 01:29 PM   #12
Y-Blockhead
Y-Blockhead's Avatar
As strange as it sounds I couldn't find a spring loaded curtain rod locally so I made my own 'gauge'. I like 'making' my own tools anyway.
Old 09-01-2015, 01:45 PM   #13
hardtimes
hardtimes's Avatar
Good thinking ! What does the measure guage look like ?
Old 09-01-2015, 03:07 PM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
How high up are you measuring? The 1/16" is for 6" off the floor.
Old 09-02-2015, 09:38 PM   #15
Y-Blockhead
The 'measure gauge' I just mark the 'plunger' and adjust to 1/16" (+/- 1/32") toe in (~6-7" off the floor as Chuck said, front and back
Old 09-03-2015, 07:33 AM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
For the plunger on the wood rod you could use a bolt or threaded rod and nut with 16 threads per inch, then set the nut to touch the wood when on the front side, roll the car forward and adjust the tie rod to get one thread showing on the rear.
Of course when the rear is changed, the front will be also, so be sure to recheck the toe in both front and rear after making the adjustments.
Old 09-03-2015, 08:42 AM   #17
Y-Blockhead
Good point Tom. Yes it wasn't actually as easy as I made it sound. I did have to recheck and have to readjust.
Another point Tom made is to only roll forward.
Old 09-03-2015, 11:34 AM   #18
BILL WILLIAMSON
Refer to post #11.
Bill W.
Old 09-03-2015, 10:47 PM   #19
Phil Brown
Phil Brown's Avatar
Made these up the other day, real easy to use just push up to the tire hook a tape in the cut in slot on one side and read the number on the other side. I like to use two tapes and just leave them there (one front and one in the back) as you make the adjustments
Got a set for the race cars that are made out of a bent aluminum plate that work real good too
Phil Brown is offline   Reply With Quote
Old 09-04-2015, 07:27 AM   #20
Tom Wesenberg
The problem is unless the wheels and tires are perfect with no wobble the toe in could be off. 1/8" wobble is acceptable and if each wheel has 1/8" wobble, that could throw off the measurement by a lot.
