Old 08-30-2015, 08:49 PM   #1
Larry Jenkins
Default Re: Plastic window in sand blaster..
Jim Brierly, or others..
Is there a special type of Saran wrap that clings better then others?
What is the name of the window film? Does it stick well to the plastic window?
TIA!
Larry
Larry Jenkins is offline   Reply With Quote
Old 08-30-2015, 09:57 PM   #2
JRHASZARD
JRHASZARD's Avatar
I would think that glass being harder than plastic, would erode more quickly. My cabinet has very dim lighting. The socket limits the wattage of the bulb, but I don't remembet what that is. I think I will go with the curley flourescent like Tom says. If that doesn't do it, I will cut a hole in the top and install an external light that shines down into the chamber. The thing works great but I can't see what I am doing.
JRHASZARD is offline   Reply With Quote
Old 08-31-2015, 04:37 AM   #3
noboD
TIA!
Larry
Use double stick tape. And the film goes on the INSIDE of the window, not outside like someone I know.
noboD is offline   Reply With Quote
