Old 08-11-2015, 02:34 PM   #1
Elcastor
Elcastor's Avatar
Default 1928 -29 Radiator Cap
My radiator cap does not tighten down on the radiator threads. Is this a problem with reproduction radiator caps? Anyone else experience this problem
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 08-11-2015, 04:19 PM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: 1928 -29 Radiator Cap
It doesn't need to be tight. It isn't a pressure system.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-11-2015, 06:12 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The cap MUST be TIGHT & LEAK FREE, why else would they put a GASKET in it? Since it's NOT a pressurized system, why not just throw the cap away & use RAIN-X------------------
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-11-2015, 06:21 PM   #4
700rpm
700rpm's Avatar
Ben, yes, there are some that do not have the proper thread, and often the profile on the lower rim is wrong. The Vintique caps are like this. I got a good one from Bratton's. Unfortunately, all repros are chrome plated, not nickel. Why do they do this to us?
Ray Horton, Portland, OR
Old 08-12-2015, 01:38 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I've seen some original radiators with threads that are worn and don't grab more than the last 2 or 3 threads. My original 28 is somewhat worn, but still grabs enough threads to tighten and seal.
Have you inspected the cap threads or tried a good original cap?
Old 08-12-2015, 02:05 AM   #6
dave in australia
To further Bill's comments, if the cap is not tight, or has no gasket, then as the water expands due to heat, some drops will come out and put rusty water stains on your nice shiny paint, and windscreen. There won't be enough to block you vision, but then you still have to clean it. Not all the water will go out the drain tube, some will take the path of least resistance, or is that path of best convenience??
dave in australia is offline   Reply With Quote
Old 08-12-2015, 02:13 AM   #7
Mitch//pa
agree with post 3-4-5-6 the cap should be tight to prevent any spill over or even steam vapor to escape out the top...
Old 08-12-2015, 05:26 AM   #8
jimalabam
jimalabam's Avatar
Post two = left field FOWL...
jimalabam is offline   Reply With Quote
Old 08-12-2015, 09:51 AM   #9
Elcastor
Elcastor's Avatar
My guess is that it was purchased from a very reputable dealer, as that is all I ever use. I think I will order another one, and also try screwing on an original once I get back "home".
Ben Purkey
Old 08-12-2015, 04:54 PM   #10
BILL WILLIAMSON
In a pinch, IF you CAN'T get your cap sealed perfectly, use a REALLY BIG, tapered CORK PLUG. It would also look "COOL'' with a meat thermometer stuck in it. A friend sweated a 1/8"NPT X 1/8" ferrule adapter into his top tank & put a meat thermometer in it, for quick temp monitoring, while workin' under the hood.
Bill W.
Bill W.
Old 08-14-2015, 11:41 AM   #11
26Tguy
26Tguy's Avatar
I had this same problem so I cut a gasket from 1/8" rubber and added it to the cork gasket for it to seal.
However, on my repro cap, the threads were welded in on an angle that pitched the threads an 1/8" off from the outer "shell" of the cap. It's very difficult to screw on and when it is on, it is crooked. UGH! Guess I got taken on that purchase! THANKS Mac's!!!!
26Tguy is offline   Reply With Quote
Old 08-14-2015, 02:19 PM   #12
Fred K-OR
Fred K-OR's Avatar
Ben, I am sure you checked this but could your radiator shell be sticking up to far and the cap hits it? I had one of my rigs do that with an aftermarket shell and I had to grind the shell down a bit.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
