Old 08-08-2015, 07:36 AM   #1
Ted Duke
Default Re: Emergency brake lever springs How do you install?
Originally Posted by Tom Endy View Post
The first effort is to determine which is left and which is right. Years ago at a club seminar the discussion about which was right and left went on for 15-20 minutes. When all finally agreed, it was wrong.
There are also some poor quality springs on the market that are too small, and you will have fits trying to install them. Be careful where you buy them.
The Sept\Oct 2013 Restorer has an article by Les Andrews about how to install the springs. He has made up two tools out of screwdrivers. He also shows a photo of the springs indicating left and right, which is certainly a big help.
My preferred method is to use a coat hanger wrapped around a screw driver handle to pull them into place.
Tom Endy
And, beware. I received a new set from a favorite vendor and they were the same. Two lefts or two rights, I forget now. After scratching my head for a day I called and they sent another set.
Ted Duke is offline   Reply With Quote
