Old 08-07-2015, 03:09 PM   #2
JSeery
JSeery's Avatar
Default Re: 1939 ford brake lights stuck on
I'm not sure I'm following this. Why did you replace the master cylinder in the first place? You have a new pressure switch, did something happen to it? Is the new switch broken? Why not get another one? There are several upgrades you could do. Get a new low pressure switch or replace the pressure switch with a mechanical switch.
