Old 08-04-2015, 09:32 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Pistons
About 60% of the power losses due to friction are caused by the pistons in a conventional internal combustion engine. Another parasitic power loss is due to the mass of pistons. Then why are we using 1920's piston design technology in our Model "A" & Model "B" engines wherein pistons have very long skirts?
Is there a Model "A" & "B" engine builder out there that uses modern pistons?
Bob Bidonde
Old 08-04-2015, 09:45 AM   #2
Rex_A_Lott
Default Re: Pistons
I've read several posts on using the "283" style pistons, which is just a referral to the modern slipper-skirt pistons, I believe.
I think I've even read where some of the racers and hill-climbers are using narrow rings to cut down on the drag you mentioned.
Pete and Jim Brierley to name a couple ought to have some good input on this, if they decide to chime in.
Rex_A_Lott is offline   Reply With Quote
Old 08-04-2015, 09:51 AM   #3
modelAtony
modelAtony's Avatar
Default Re: Pistons
Pete's automotive in Alb, NM owner John Cosper builds engines and also uses modern piston of the chevy uses the new way with mounting the rods . He has a very good rep of inserted engines . Years ago they were among the first that started the inserts. Johns dad is MR PETE. Many years ago they were the go to guys for inserts. Years have passed and now many and most builders have gone to inserts but MR BOB and John were the ones that got the ball rolling. I would give John a call and talk to him. Have fun modelAtony tony white Lafayette, LA and a very happy customer of PETE'S AUTOMOTIVE 7 year old inserted engine and no adjustments on engine yet.
modelAtony is offline   Reply With Quote
Old 08-04-2015, 09:58 AM   #4
johnneilson
Default Re: Pistons
There are many factors to the piston design, too many to list here.
However, the stroke length and rod ratio does have something to do with the longer skirts. Modern lubricants and proper clearance will eliminate quite a bit of the drag, due to the fact the cyl is not cooled uniformly at the bottom more clearance is required, this makes the longer skirt more desirable.
IMHO, the rings are more of a parasitic drag factor then the skirts. I have been having my pistons made with modern car ring packages and like the results. Sealing is very good and the oil control is excellent.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 08-04-2015, 10:45 AM   #5
Jim Brierley
Default Re: Pistons
Many use pistons from Pete's. I have used 1955, 324 Olds pistons with good results, they require enlarging the pin hole a little but have the correct pin height. Both have narrower rings.
Old 08-04-2015, 11:48 AM   #6
John
John's Avatar
Default Re: Pistons
For "New Style" pistons contact Richard Fallucca at the listing below and I think you will be pleasantly suprised.
ANTIQUE ENGINE REBUILDING
4835 LOUISE
SKOKIE, IL 60077
847 674 6716
John is offline   Reply With Quote
Old 08-04-2015, 11:49 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Pistons
Actually, the pistons from a Chevrolet are heavier than what is available in aftermarket from most Model-A parts vendors. And, adding to that, those aftermarket pistons are heavier than original pistons by a substantial amount too. Heck, the wrist pins alone have about 100 grams of difference between the lighter original pin and the aftermarket pin.
The best available that I know of are the pistons that Rich Fallucca now offers. They are modern technology and are made specifically for the A/B. Call him if you want more info on them.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-04-2015, 01:29 PM   #8
Pete
Default Re: Pistons
I use Ross.
They are forged.
They will make them to your specifications.
They will assist you in selecting the right piston for your application.
Old 08-04-2015, 01:44 PM   #9
Ed Pitts
Ed Pitts's Avatar
Default Re: Pistons
Here are the 283 style pistons that I obtained from John Cosper and recently installed in my car.
Ed Pitts is offline   Reply With Quote
Old 08-04-2015, 02:00 PM   #10
BRENT in 10-uh-C
Default Re: Pistons
Did you weight them either with, --or without the pins?
BRENT in 10-uh-C
Old 08-04-2015, 02:26 PM   #11
Ed Pitts
Ed Pitts's Avatar
Default Re: Pistons
Did not weigh them.
Old 08-04-2015, 03:55 PM   #12
BRENT in 10-uh-C
Default Re: Pistons
Did not weigh them.
My experience is the Chevrolet pistons are heavier. The only two advantages that I knew of was the costs (much cheaper buying in a set of 8) and the thinner ring (less parasitic drag)
BRENT in 10-uh-C
